149 PTO always on.. please help me buy parts
My 149 PTO is always engaged. I plan on buying a wear button, thrust button, and two throw out levers from a local Cub dealer. Should I do anything else at this time? Should I have a third throw out lever? The diagram shows one and I have two.
Finally, this IS a type "A" PTO, correct? |
Depending on serial numbers of your 149 your PTO should be either B or B with brake. This PTO you have looks like a B (without brake).
https://www.onlycubcadets.net/forum/showthread.php?t=9 Sponsors above have the parts. Cub Cadet service and parts look up has nearly everything you need but maybe it might be best to buy a rebuilt/refurbished. Don't forget the bearing and the thrust button.
Two 125's and a 124 all with 42" decks Plow blade #2 Cart QA36 snowthower |
There are three throw out levers.
In addition to what you listed, you will need the screw(26), spring(24), and two nuts(23) for the third lever. While you're waiting for parts you should be soaking the Allen screw holes in the pulley with penetrating oil. |
What's up with the GIANT pictures??!!!
My PTO works fine for now, but I wouldn't be surprised if more stuff breaks on it if I tear it apart. |
I would not run that PTO as there will be more damage, especially to the PTO thrust lever.
I'm pretty sure that PTO you pictured looks like a B type but maybe I'm wrong. Perhaps some else can chime in. I have an A type in my 125 and I can see the differences.
It is a B Type with a PTO fingers that are long gone. It may be one with or had a brake style pto, serial # would be 482000 and up.
Interesting. Serial is 404000 and some change. I'm going to assume it has had an engine swap at some point.
Thread Tools | |
Display Modes | |
