2166 hard to start - Choke Plate Alignment
I have a 2166 that has been hard to start (that is it turns over, but takes a while to start). Once started, it ran great.
From sources like this forum I tried lots of things: > Checked spark- looked good > Checked fuel flow - fuel pulses out of the filter when turning over > Checked choke linkage - fully closing > Cleaned carb It would still take 10-20 seconds to start. Then I noticed the kohler carb rebuild instructions included a short section on adjusting the choke plate. 'To align choke plate, insert a 0.010 in. shim between the top right edge of the choke plate and bore.'I loosened the plate screws, adjusted the choke plate and re-tightened. It starts much quicker now!! This adjustment solved a nagging slow to start issue for me. Maybe this could help someone else with a slow to start kohler. |
I add a primer bulb for my hard starter's. Pump it up and instant start.
Thread Tools | |
Display Modes | |
