Old 12-14-2011, 10:47 AM
martinsuper's Avatar
martinsuper martinsuper is offline
That's a good looking 122 you got there! I see your farmall In the background, do you have a bushog or finish mower? I used to have one with a bushog, kinda miss it.
It is a brushhog "style" but it is meant to be a finishing mower. I found new blades for it at a VERY old Woods/IH dealer with about two inches of dust on them. The old ones had been sharpened down to about half their size and 3/4 the length. Now it cuts like a laser!
I kept the old blades for decoration, and to laugh at every once in a while.
Old 12-16-2011, 11:39 AM
nikster's Avatar
nikster nikster is offline
nikster
What model are you putting on your 122?
One off a wide frame will not work,even a qa36a or 42a will not work either.
We need pictures!!!!!!!!!!!!!!!!
Just saw a snowblower on e-bay his comment was that a q36a was adjustable. It will fit a narrow frame that's what the - a - is for --adjustable.
Also I talked to a fellow member who lives near by & is coming over on Sat., to show me what to do.
Nik,
Old 12-16-2011, 12:24 PM
Nik,
Nik, check out the manual maybe it'll give some more insight. I've never used a thrower/blower.
http://www.onlycubcadets.net/forum/s...ead.php?t=7431
Old 12-16-2011, 05:24 PM
martinsuper, nice rig you got yourself, you'll enjoy this addiction.
Don't know if you are aware, but you'll need chains for blowing, the weights alone won't cut it.
Old 12-17-2011, 09:25 PM
nikster's Avatar
Update on snowthrower;
Rick (member) was kind enough to stop over this morning & showed me how to adjust my snowthrower wide frame to a narrow frame. Chit chated for an hour or so & he left to save his daughters car who had a problem with starting it. All in all I just have to buy are 2 frankenstine bolts & 2 roller pin. Since he visually pointed out what to do IT'S SIMPLE.
Also reviewing this owners manual above, the link above IS CLEAR on what one must do to adjust from a wide frame to a narrow.
Soooooooooooooo thanks Rick & Methos for all the HELP.
Nik,
Old 12-17-2011, 11:07 PM
ricks ricks is offline
nick. your very welcome. it was a pleasure meeting with you face to face. i expect that 122 to be ready for flinging snow next time we get some. but at that rate you'll probably be putting the mower deck back on. that 122 is a nice looking tractor. you have a great setup there as far as working conditions also. if you need any other help with your 109, don't hesitate to call. i had a chance to mull over your idea for the tranny support, and i don't see any problem with what you've come up with. make sure to take some photos of that and post them here. that's a handy fix. also take some of when you change the plate configuration on the snowblower so others in that situation can get an idea of how it's done. i need to get back out to the garage and fix a gas leak on the "original". when i got back from fixing my daughters truck i could smell it through the service door. thankfully, no one was home. i'll chat with you later. rick
