Old 01-11-2012, 12:09 PM
340demon's Avatar
340demon 340demon is offline
Default Fluid in tires
Just filled up the rears with washer fluid almost 5 gallons in each! My dad and I pumped it in with a bug/lawn sprayer! Guy at tractor supply suggested it instead of calcium. Just a thought, I'd throw out there?
Old 01-11-2012, 12:35 PM
Calcium is 1950 technology. It will rust your rims or anything else in comes in contact with. You will be okay with the ww fluid.
Old 01-11-2012, 02:05 PM
CHWNY's Avatar
CHWNY CHWNY is offline
I Use RV anti-freeze it's NON-TOXIC and has rust inhibitors. I also use a pump sprayer, works great!!
Clay
Old 01-11-2012, 03:24 PM
cubguy's Avatar
cubguy cubguy is offline
personally, I have never filled any tires but my neighbor took his GT (another color) to the local tractor dealership for fluid. They used half water and half antifreeze. seemed to work just fine.
Nroakes
Cub Cadet 3206
Allis chalmers B112
One big Green tractor
Old 01-11-2012, 04:23 PM
340demon's Avatar
Ya never thought of antifreeze thats also a great idea!
Old 01-11-2012, 07:11 PM
CHWNY's Avatar
Regular Automotive antifreeze is VERY VERY TOXIC and should not be used for this application!!!!
Clay
Old 01-11-2012, 07:37 PM
krhoover krhoover is offline
So is WW fluid.Yet we all spray gallons of it on our windshields every year that ends up in the ditches, rivers, streams and ground. Along with that all the gasoline, carb cleaner, starter fluid, PB Blaster, WD40, ect., that we use and consume. If someone is not purposly polluting,and putting it in a sound tire, I see no problem using it. All vehicle owners have gallons of it sitting out in their driveway, many of them leaking. IMHO
Old 01-11-2012, 07:40 PM
weaverama weaverama is offline
Yes, if it leaks out the dogs will lap it up like nobody's business. Don't let it leak out.
Cub 108
Cub 1650
Cub 1000
Cub 682
Super Cub 2072
Old 01-11-2012, 09:27 PM
The antifreeze is expensive, I would work hard not to loose it.
Current production antifreeze should have bitters in it to stop animals from drinking.
Tractor tire dealers near here use a low cost version of antifreeze without the engine protection products in it.
A 50/50 mix is not necessary unless you shed gets to -50 degrees.
Just mix per container instructions to get the freeze point that is below your local low temp.
Personally I change the antifreeze in the truck, dilute what I drain out and use that. Kills two birds with one stone!!
Old 01-11-2012, 10:14 PM
maddog784's Avatar
I went with the antifreeze myself - worked pretty well. I mixed 3 gallons antifreeze to 4 gallons water. The mix should keep the tires from freezing up anywhere above -20 F. In southwestern PA, this should suffice. As far as filling method - BREAK THE BEAD! It was by far the easiest method I could think of.
CCC 784 w/ Triple Hydraulics
IH 982
50C Deck
41" IH Rear Blade
QA42A Snowthrower
