Old 01-11-2012, 03:10 PM
Love my Super 1872 Love my Super 1872 is offline
Default Northern Virginia Cub Cadet Mechanic
Sirs,
Is there someone in the Northern Virginia area that I could pay to rebuild my 1872's carbureator and tune up the engine? Are there any reputable shops?
Old 01-11-2012, 06:26 PM
weaverama weaverama is offline
The Walbro carburetor on your super is easy to rebuild. I would not worry too much about finding a reputable shop to do it, in fact, I would suggest doing it yourself if your throttle shaft is not too sloppy. That gets a little difficult. Most any shop that services small engines can rebuild a Walbro, they are pretty common carbs. And, unless they are totally inept, they should be able to do it correctly.
Why do you think it needs a rebuild and not just an adjustment?
Cub 108
Cub 1650
Cub 1000
Cub 682
Super Cub 2072
Old 01-11-2012, 09:13 PM
We want to see pics of your 1872!
Old 01-12-2012, 10:16 AM
I was told by a fellow owner that it probably was worth rebuilding.
Old 01-12-2012, 11:54 AM
Im not sure as to your mechanical experience but cleaning the carb is one of the simpler tasks or can be . I suggest you check out youtubes selections on small carb overhauls.
It just takes a clean bench ,good carb spray w/tube , safty glasses , patience ,good eyesite and ofcourse a little instruction. just be sure to not loose any part
A funny note 15-20 years ago my mom mowed her yard , and I stopped by for lunch from work . she was upset that the mower quit half way threw mowing. So after lunch I started to take the carb apart and saw the bowl was contaminated , a lawn boy 2 cycle. Mom was early 70's and not mechanically inclined, but had watched every thing I did she was kind of mad I didn't get it running then, but I was going to be late back to work already . when I came home after work the mower was back together , she told me she put it together but she could not get it to start. I looked and it seemed to be OK ,it started fine on the first pull.
