Old 05-12-2012, 08:34 PM
Default cheap bush cutter
The other day at the thrift store ,they had a lot of battery powered hedge clippers and of course the batterys are shot , & no charger , for $3 I bought it and wired a cord I had ,added a house hold outlet to the back of my current LT MTD . I like it ,it trims my yews and shrubs will cut 1/4 inch branch ok I planted alot of red cedars to screen my land and want to trim them .
Probably mount it to the 128 next
homemade battery install too, and that guy at the parts store said it couldn't be done.
Old 05-12-2012, 08:49 PM
Now you have an excuse to get a FEL to pick up all the branches!!
Great rework!!
Old 05-12-2012, 09:38 PM
Nice work!
Old 05-12-2012, 10:57 PM
cmatthew's Avatar
cmatthew cmatthew is offline
and i thought it was something i could get for my wife when i read the title!!!
Old 05-13-2012, 05:32 AM
yesmar74's Avatar
yesmar74 yesmar74 is offline
That's funny right there ---I don't care who you are
1973 149 with 44" Deck, 782 with Simms cab, 1966 102 with 38" deck, 50" deck, 5 42" Blade, Brinly 8" 3- point Plow, Brinly 10' Sleeve hitch Plow, Brinly 12' 3-point Plow, 782 Pile, 2-38' Decks, QA-42A,1650 Roller, QA42 Thrower, Kubota BX 2360, 1970 IH one ton 4x4, one 1959 farmall cub restored, two 1949 farmall cub projects, cub grader blade, 5 sickle bar mowers , 1 set cutivators , 1 fast hitch plow, 1. 1950s IH hay rake
Old 05-13-2012, 08:39 AM
You can, see runs the cutter and you operate the mobile power supply
Old 05-13-2012, 07:41 PM
EarlJ's Avatar
EarlJ EarlJ is offline
I hate to say it, but thats some pure redneck engineering right there..prettly slick little set up though...
Old 05-22-2012, 11:10 AM
westofb's Avatar
westofb westofb is offline
You could improve your design by adding a cheap retractable power cord like they use on shop lights, that would be easier than having to worry about the cord getting snagged on stuff. Also, why not just use a cigar light plug and socket, would look a lot neater than the household outlet and plug (of course that would eliminate the "redneck engineering" that went into your project...LOL)!!!!
Jeff
Brookfield, MO
________________
Old 05-22-2012, 01:03 PM
jdroison jdroison is offline
Exclamation
just dont let anyone plug it into a real outlet.......
Old 05-22-2012, 02:18 PM
Yamaguy's Avatar
Yamaguy Yamaguy is offline
Wow that was a great idea!! I wonder how much of a strain that would put in the starter/gen?
Dale
147-Restored___________________882 Diesel
Hydro lift (not installed)___________44" Deck
48" Deck_______________________QA-42a/b Snowthrower
Rear lift ________________________XMW cat-0 rear lift
Model 2 tiller____________________12" cat-0 Brinly plow
