Old 06-26-2012, 10:27 AM
Thanks for the pics, Adam! Looking forward to your updates.
Old 06-26-2012, 11:17 AM
Looks like a good start for your restoration BTW the 107 has only a 6 1/2
qt fuel tank...
Up to 534 and counting...
Old 06-26-2012, 11:42 AM
ToddW's Avatar
ToddW ToddW is offline
Straight and clean! looks Great
Cub Cadet 108, IH snowthrower, IH ?? mower deck
Cub Cadet 1650, IH 44 mower deck, IH snowthrower
1960 Cub LoBoy- yellow roundnose. Fast hitch w creeper and roto tiller, front blade, mower deck and Fast hitch one bottom plow and rock rake
1951 F Cub with Wagner loader and woods brush hog, 152 disk plow and 23A harrow
1953 Ford Jubilee tractor and F100 Pickup
Old 06-26-2012, 12:16 PM
TheIHMan's Avatar
TheIHMan TheIHMan is offline
Thanks for the comments! As far as the fuel tank modification the reason I'm doing it is because I have a LOT of yard to mow. To put this in perspective it takes the diesel 2.5 gallons of diesel to do the whole yard and the diesel is pretty conservative on fuel. Plus I won't have to worry about being low on fuel or carry fuel with me to plow days. And I already have another tank at the farm that is the same size. So once I am finished with it it will have 3.25 gallons of fuel capacity. Anywho today I got the battery cable run and fixed float on the carb. Later this afternoon I will start on fixing the wiring. I am going to napa later today to get the coil, spark plug, plug wire and ground cable for the battery. Once I get those things on it should be ready to start. So hopefully i can get it running today!
Old 06-26-2012, 02:14 PM
TheIHMan's Avatar
Been doing some more work and I found that where the drive shaft connects to the engine there is a nail there instead of the pin. My question is, is it a roll pin or what kind of pin is it and where can I buy one?
Old 06-26-2012, 07:16 PM
Yeah I don't understand why the need for so much fuel either. I'd much rather have the batt. under the hood, but that's just my opinion.
Good luck on your conversion.
Old 06-27-2012, 12:09 AM
TheIHMan's Avatar
Well I finally came to the conclusion that the wiring mess is unfixable so I'll have to go to the farm sometime and take the wiring system off the parts 147. Heres some pics
Old 06-27-2012, 10:16 AM
TheSaturnV's Avatar
You'll want to have a look at that coupler, it's probably pretty mangled up having that nail in there. I've bought roll pins at Lowes Depot, TSC and ACE Hardware.
Old 06-27-2012, 01:00 PM
TheIHMan's Avatar
Yeah I'll fix that when I pull the engine out to paint it.
Old 06-28-2012, 05:17 PM
TheIHMan's Avatar
Ok so I've haven't done much because of the heat but like I said earlier the wiring harness is beyond repair. So my question is Can I buy a new wiring harness and if so where?
