Cub Engine Swaps
I have a IH CC 108 with a ten horse engine in it, I have pulled it, it pulls ok but needs more power. So I found a guy who has 14hp and 16hp engines. Im thinking of getting a 14 hp engine, like one out of a 147. Is it simple to convert the hydro powering engine to a gear drive powering engine. I have not seen a hydro up close. I imagine I can take the hydro parts off the 14hp and bolt on the 3 pin driver onto th 14hp. Can I? Thanks for any help you can give me.
International Cub Cadet 71 with deck International Cub Cadet 108 with plow, deck, chains, single bottom plow,Sleeve Hitch. IH Cub Cadet 122 project Case 444 withs ags, plow |
The engine is a direct bolt in if the engine came from an IH Cub Cadet. Make sure you use a #30 carb if you go to a 14 or a 16 horse power engine.
My Son owns a 86 with a K321 in it. He used a wire harness, charging system and starter from Quiet Line Cub Cadet. |
