Old 07-21-2012, 06:12 PM
David Gallagher David Gallagher is offline
Default 1440 Smoking
My 1440 smokes a lot(white smoke) when I first start it. After that, it runs and performs pretty well. The motor has about 500 hours on it and was not maintained well before I got it. Any ideas on something simple. I don't think it is worth rebuilding as it has other problems too
Old 07-21-2012, 07:14 PM
Make sure it's not over full with oil and check to be sure the air filter is clean.
Old 07-22-2012, 03:00 PM
GDahmes's Avatar
GDahmes GDahmes is offline
David, I have a 1440 also. I had the same problem. I had changed the oil, and I over filled it. Once I drained the excess oil out the smoke was gone. It has run just fine since. Your air filter could be wet with oil, if that is the problem. I have a hard time seeing the oil level on my dipstick. Really hard to tell where it is at.
Did you come by it recently? I would think you would want to change all fluid levels, filters and plugs, especially if you have concerns about the previous owner.
