They are 0.469" long (IIRC) with a 5/16" ID and perhaps a 5/8" OD. There's one under each mounting bolt, and the engine is not properly aligned without them.
You're off to a great start, buddy!
So, do they go under the plate? Or between the engine and the plate? Thanks, Allen!
-105___ Tiller |
The spacers go between the plate and the engine. In other words, the spacers sit on top of the plate, then you set the engine on top of the spacers.
Josh Diesel Cub Cadets........... |
I've checked...I defiantly don't have the spacers. Looks like I'm just going to take the dimensions to the hardware store and pick 4 up.
-105___ Tiller |
Got some better rears on the back, to help in rolling. Now just need to get a tube in the front right tire.
![]() Once my new push button starter from Ebay comes in, and I get some spacers, I can try and see if she will run. At first, I was a little overwhelmed by this tractor. But looking at it, now...It really doesn't look so bad.
-105___ Tiller |
Maybe I should have sold you my 682 Connor. The one I have is not a whole lot more disassembled that that one!
AJ
1980 [COLOR="Red"][/COLOR]482- Stock 1981 [COLOR="Red"][/COLOR]582- Mag18, Sleeve Hitch, Spring assist 1979 [COLOR="Red"][/COLOR]682- Mag18, Sleeve Hitch, Spring Assist, #1 Tiller 1980 [COLOR="Red"][/COLOR]782- Mag18, Sleeve Hitch 1983 [COLOR="Red"][/COLOR]982- Stock, Fully Optioned |
