Old 09-25-2012, 02:14 PM
alsparl alsparl is offline
Default GT or SGT Deluxe (Metal) Cab
I have come across a metal cab that should fit a GT or Super according to the Cub Cadet Attachment Guide I photocopied from the dealership days. I am working with a friend on it to get it properly attached to his machine. From what I can see, Cub Cadet listed them under two different part numbers, 759-3594 or 759-3192.
Does anyone have any mounting instructions for either of these? If possible, I would really appreciate the opportunity to obtain them somehow.
Thanks!
Aaron
Aaron
'83 782 #723927
****original KT series 1 engine
****added dual hydraulics from older, donor 782
'04 SRC621
'95 Magnum (M18S) spare engine
****spec 24646
****s/n 2507913316
Old 11-19-2012, 12:27 AM
So here it is. Do you think this cab unit would fit on my 782? Or is this geared more towards the SGT tractors? Anyone have any mounting instructions for this unit as well? The only mounting brackets I see at this time are the two "arms" in the rear. Thank you for your viewing and info.
Aaron
'83 782 #723927
'04 SRC621
****spec 24646
****s/n 2507913316
Old 11-19-2012, 12:33 AM
That's a nice cab! Great find!
Old 11-19-2012, 01:27 AM
Great find on the cab! The fender pans are the same so it should fit without much trouble.
Old 11-19-2012, 07:30 AM
X2!
Old 11-26-2012, 05:47 AM
squatch squatch is offline
The only difference with the Supers is the steering wheel will be more forward. My cab is for a regular GT but works well enough on the Super as the fender pans are the same. Looks like yours attaches to where a rear frameplate would on each side. Here is a link to many pics of mine for reference. Different rear mount but front is close enough.
http://www.onlycubcadets.net/forum/s...ead.php?t=7382
