Old 06-10-2012, 03:08 PM
riesedesperado6170's Avatar
riesedesperado6170 riesedesperado6170 is offline
I use a 120v water pump From TSC it has garden hose hook ups on it. i modified it by puting a switch on it so i shut it off with out unpluging it
Old 06-12-2012, 01:01 PM
123Pokey321 123Pokey321 is offline
I have my 23x10.5x12 turfs filled with Rimguard and they weigh between 112 and 114 lb each. That stuff is incredibly dense. I just picked up a set of 23x8.5x12 dual AGs and I'm still debating on having them filled with Rimguard or just filling them myself with antifreeze/windshield washer fluid.
Old 06-12-2012, 06:53 PM
Flatbedford's Avatar
Pokey,
How much did you pay of the RimGuard?
Steve,
Former multiple 149 owner.
Old 06-12-2012, 08:14 PM
bllwnkl's Avatar
bllwnkl bllwnkl is offline
Now what do I do? I've already invested in the air/water adapter at TSC, a pump. and some hose to fill my tires myself. I'm debating between wwf and rv antifreeze. I don't have the fluid yet.
I decided to email RimGuard just to see if their were any dealers close to me. Well there is, and he told me it would cost me $17 a piece to load my 23x10.5-12 tires!
What would you do? Please
Old 12-15-2012, 12:50 AM
72-149's Avatar
72-149 72-149 is offline
i would go with the rimgaurd (beet juice) it dosent rott the rims or tubes like windshield washer fluid or antfrez. does & if you poke a hole in your tire the dogs or what ever comes inconntact with it dont get sick & die.w/wf weight is 8LBS. per gal. rimgaurd is 11-12 LBS. per gal. i had it put in my 26x12x12 ags 75.00 for both.
Old 12-15-2012, 05:41 PM
cub149's Avatar
cub149 cub149 is offline
I'm cheap so I made my own fluid. Used 1 gallon of methanol with 9 gallons of water in my 26 12 12 tires. methanol is what is used in windshield washer fluid and it's only $4 a gallon. So to fill two tires it cost me $8. I did a quick search and found a % for the methanol but they didn't give any degrees for it but basicaly said for cold temps use 10% and for extreme cold use 15-20%. I'm in NC plus my tractors stay inside so I just went with 10%.
Also my tires have tubes so I used the adapter kit from tractor supply, hooked a peice of garden hose to it and sucked out all of the air from the tube with a shop vac (first you have to break the bead in just one spot to let air in between the tire and tube or it will suck the tire in, ask me how I know). Then I hooked the hose to a container and let the fluid flow in. I had read that people where putting 10 gal in one tire so that is all I put in. Also, before I did any of this I put the new tubes in and filled them with air and let them stretch out for a couple of weeks.
It takes about an hour to fill each tire so I did it while I was working on other projects.
Chip T.
Drexel NC
Old 12-15-2012, 06:13 PM
Leadslingingdaddy's Avatar
Just pop the bead and pour the fluid in....15 minutes....Done...
Old 12-15-2012, 06:31 PM
cub149's Avatar
Only if you don't have tubes
Chip T.
Drexel NC
Just remember that will only work with tubeless tires.
Remember fill to only 90%
explaining:
When the valve stem is @ 12 o'clock liquid is just trying to spit out. (tire/wheel installed on tractor)
This allows for the adjustment of air pressure without fluid loss and keeps a small cushion of air so no injury to the tire if it incounters a hard hit.
also pulls better in the field(traction)
Old 12-15-2012, 07:33 PM
cubby102's Avatar
cubby102 cubby102 is offline
I put 7 gallons of Wal-Mart's cheap -20 we fluid in the 782 and I can tell a big difference when I was pullin the yard sweeper around dads yard picking up pine needles. On some of the hills it would spin when wet it didn't even attempt to and I was riding it around right after it rained today only cost me a little over 20 bucks
