Old 12-15-2012, 08:18 PM
cub149's Avatar
cub149 cub149 is offline
Default scrape blade super cub
I see a lot of four foot scrape blades around here for sale cheap. They are all for cat 1 tractors. Is there a reason they couldn't be changed over to a cat 0 for a super to pull? I can do the fabrication that would be invloved.
My thought is the blade would be to tall? Also to wide, but that would be an easy fix with a torch.
Any thoughts?
The more beer you drink...........................
Chip T.
Drexel NC
Old 12-15-2012, 08:44 PM
Iowa Farmboy Iowa Farmboy is offline
I would be concerned with how heavy it is
Josh
1989 SGT 2072 (restored)
60"Haban Deck, 54 "Haban Blade, 48" Cub Cadet Tiller, 12" Brinly Cat O plow, 48" Cat O landscape rake
Cub 128 with creeper and rear PTO with reverser(next project)
IH built 682 and 782 that will combine to make one
Old 12-16-2012, 02:33 PM
riesedesperado6170's Avatar
riesedesperado6170 riesedesperado6170 is offline
i bought a cat1 5ft for my it works good i just had to change pins that were weld on so i cut and welded new ones on some bolt on you can just get new pins
Old 12-22-2012, 02:19 PM
Jumper Jumper is offline
Cub 149, since your going to be fabricating how about a grader blade to go under the center of your cub. Guy's that have them like the way you can work the ground compared to the front mount, I guess it's all what you like but I have been playing with the idea myself to build one. This one in the picture is one that got away a couple of years ago...........
Old 12-22-2012, 02:38 PM
Another thought, these box scrapers are not all that complicated either, since your building one you could make it as wide as you wanted. I have a rear blade I use on my 1650 and I like the box scraper way better, again all what turns you on
I hope you can see the pictures, I have seen them converted to work on a 982's cat zero 3 pt.
