Old 03-20-2013, 06:08 PM
bocephus1991's Avatar
Default Hy-Tran in Truck transmissions?
Has anyone ever heard of or know anyone who has used Hy-tran in their manual
trannys or auto trannys for their pick-ups or cars? Any reason it wouldn't work? thanks,Brian
Brian
Old 03-20-2013, 06:15 PM
TheIHMan's Avatar
TheIHMan TheIHMan is offline
I don't see why it wouldn't work. It's the best stuff out there for Cub Cadets and tractors.
Old 03-20-2013, 06:30 PM
It would be my opinion to go with the factory recommendation in an automatic transmission, as some have specific needs, that possibly hytran would not best be suited.
on the reverse, ATF is specified as an alternative by Sundstrand.
The fact that hytran absorbs moisture might not be a good thing in an automatic where an emulsion of water/oil
would cause a problem, but I'm no oil expert.
At the cost of hytran, I would think mercon or Dextron would be economically a better choice.
Replacing a automatic is a costly experiment compared to a used hydro for maybe $100.
Old 03-20-2013, 07:35 PM
My S-10 5 speed manual requires synthetic.
Many manual transmissions require sulfur in the oil.
Hytran meets neither requirement.
Automatics are so expensive, I would not second guess the designer.
Old 03-20-2013, 07:39 PM
Muzzy Muzzy is offline
I think ol' George hit it on the head. Hytran isn't for everything.
Old 03-21-2013, 12:53 AM
Mr.Goffena's Avatar
Mr.Goffena Mr.Goffena is offline
I use hytran in my font and rear diff on my pickup. I haven't run it very long like this, but a guy I work with has been running it in his ford for 250,000 miles with no problem. Its really noticeable in the wintertime. Hytran has more friction modifiers than gear oil does Plus CaseIH use it in some of there front diffs and planetaries so I don't see why a pickup could not use it. I would not use it in any transfer case that uses ATF because in really cold weather the oil could be to thick and ruin the pump, same goes for an auto tranny.
Old 03-21-2013, 08:23 AM
gcbailey's Avatar
gcbailey gcbailey is offline
so I shouldn't be using it as a teeth whitener?
Gary
Old 03-21-2013, 09:32 AM
I think it'll be OK for that.
Old 03-21-2013, 11:04 AM
Nope but it's great for having that tractor smell on you for date night with the wife.
Old 03-21-2013, 11:29 AM
Yep, nothing like the smell of Hy-Tran!
