Old 03-21-2013, 04:34 PM
cub123's Avatar
cub123 cub123 is offline
Looks good Sam! Looks simpler than that steering box I rebuilt
Old 03-21-2013, 06:19 PM
Ben
I just can't wait till I get to do one of those. I'll give you a call when the time comes.
Old 03-21-2013, 08:59 PM
cub149's Avatar
cub149 cub149 is offline
Do you have the machinery to drill and tap the shaft or did you have it done by a machine shop? I had to pay $35 to get mine drilled and tapped. Just curious. I may send my other one to you
Chip T.
Drexel NC
Old 03-22-2013, 07:34 AM
Chip
I drilled it while the pump was together in my drill press. The fixture that I made to work on the pump held it nice and steady. Then I just tapped it by hand. Did all this before it took the pump apart to overhaul it. The shaft is case hardened so you have to go easy drilling it at first and you need a good drill bit and cutting oil.
Old 03-22-2013, 11:07 AM
Inactive Member
Chip
Too bad you didn't have this when I was working on my 2072! I could have just traded you part for part! Nice job!
Old 03-22-2013, 12:43 PM
FrankF3's Avatar
FrankF3 FrankF3 is offline
Sam Mac, what size thread did you tap the shaft to?
1989 - Cub Cadet 1772
38" Lawn Sweeper #196483
60" Haban Mowing Deck #196374
Old 03-22-2013, 04:07 PM
1/4" 28
Old 03-23-2013, 09:06 AM
Grampie Grampie is offline
Very nice Sam, Thank's for all the pictures too! I'd like to try my hand at doing that job somtime this summer. I got a 2182 w/ a broken housing and would like to get it fixed. Im sure I'll be refering back to this thread from time to time for assistance. Thank's Again!
Old 03-23-2013, 09:19 AM
You may want to look at this one also. This was my 2182 with a broken housing.
Old 03-23-2013, 01:07 PM
Bill Your lucky I already had a trailer hitched up or that 2182 would been down here with me. That would have been a sweet little swap from the 1864.
