Old 06-25-2013, 04:49 PM
vargafarm vargafarm is offline
I transfered fluid from an old full sized tractor tire to the replacement by using an electric sprayer pump.
Had to stop a couple of times to release the air.
Old 06-30-2013, 09:54 AM
alabama mike's Avatar
alabama mike alabama mike is offline
I always tube a loaded tire. Keeps the rims from rusting. I'm not sure how much your tires weigh altogether, but I weighed mine before I put them on once. I use liquid calcium. Altogether, (rim, tire and fluid) weighed right at 100 lbs.
If you use anti-freeze would that keep your rims from rusting? I want to do this to one of my tractors but just not sure what to use, I've also heard windshild wiper solvent. so just what would be the best thing to use?
disabled/desert shield/storm vet, proud to have served!
582, 1782, 124 (x2), 154 LO-BOY,
Old 06-30-2013, 10:04 AM
Mike I use RV anti freeze in my stuff but you can use windshield fluid, Rim Guard, anti freeze with out tubes or Cal if you put tubes in or you will rot the rims. Some guys have said they get used anti freeze at some repair shops cheap and use that.
I lay the tire on it's side valve core up and break the upper bead and just pour it in. I have one that has tubes so I'm going to try the sprayer pump idea, sounds like it should work good.
Old 07-12-2013, 09:51 PM
well, I got the anti-freeze gonna load up a set this weekend, thanks for the info!!
Old 09-17-2013, 09:42 AM
joenemesis joenemesis is offline
Beet juice can also be used as an alternative to calcium, it doesn't eat your rims and is biodegradable should you puncture your tire. We started using that at my dad's shop as disposing of old calcium is very expensive.
Old 09-20-2013, 05:53 AM
yesmar74's Avatar
yesmar74 yesmar74 is offline
It's so easy......9 gal. of WWF in each 10.5
1973 149 with 44" Deck, 782 with Simms cab, 1966 102 with 38" deck, 50" deck, 5 42" Blade, Brinly 8" 3- point Plow, Brinly 10' Sleeve hitch Plow, Brinly 12' 3-point Plow, 782 Pile, 2-38' Decks, QA-42A,1650 Roller, QA42 Thrower, Kubota BX 2360, 1970 IH one ton 4x4, one 1959 farmall cub restored, two 1949 farmall cub projects, cub grader blade, 5 sickle bar mowers , 1 set cutivators , 1 fast hitch plow, 1. 1950s IH hay rake
Old 11-17-2013, 11:51 PM
Shrewcub's Avatar
Shrewcub Shrewcub is offline
Well 5 months later I noticed that my 20 year old tires have some seepage I will be using tubes from now on.
Old 12-02-2013, 03:22 PM
otcp71 otcp71 is offline
One of the easiest things I have done on my 2072 with loader.9 gallons of RV antifreeze per tire.Did not use any fittings on valve stem,just rubber hose.
Old 12-02-2013, 03:26 PM
Looks like you are using some type of pump? If so what is it?
Old 12-02-2013, 03:30 PM
It's a simple small pond waterfall pump I had laying around.
Tags
tires, weights
