rust
Hello, used to see spray cans called Rid Rust, sold to companys only. A friend worked in a tin foundry and they used it to lube there conveyors. You should've seen that stuff foam and eat rust, best i've ever seen. Was used in the Cleveland area, might have been made there. Sure would like to have some. Mike
I have tried pb blaster never had much luck. All I use is kroil I have seen it do some amazing things. I had a friend that had stuck valves in his 76 pickup ,squirted some on let it sit 15min and it was freed up like new! he had even pounded on it with a dead blow hammer before and couldn't move it,it moved after the kroil oil! I tried a test with pb and kroil sprayed some on my old rusty vise 3 days later the pb dried up and the kroil you could see on it yet. I like it works for me,to each his own though!...Brian
Brian April 1979 1200 Quietline 44A deck 1988 1211 customized into a 1288 with a K301AQS 38C deck and a 1864 54” deck . Snow blades 42" and 54" . Brinly disk, brinly plow a cultivator and a $5 brinly yard rake! |
A guy I know has been restoring cars & m/c's for over 30 years & quite good at it if I may add. He swears by liquid wrench.
I on the other hand have PB Blaster & it works quite well. I soak the snot out of it & let it sit overnight, hit it again & ?. So when I run out ill try liquid wrench to keep on hand, since my projects are not going to be any major activities. Ill keep it simple. NIK,
It dont cut grass, but its yellow. |
They never tested the CHN Industrial strength rust penetrant. This is what I use and found it to work better than PB.. They sell this at the local CNH dealership along with OEM cub parts. Interesting results though and great product to test around with.
Steven __________________________________________ 127 NF, spring assist, 36" IH Danco BB-36 snowthrower, 42" mower deck. CW-36 snowthrower, 42" NF blade. QA42A blower, 126,127,149,1720. |
You can "scientifically rust" a series of bolts with salt spray.
You guys have got to try ACF-50 it is a penetrant/lubricant used primarily in the avaiation industry. I had some given to me by a family member in the industry, it is amazing. I have lost count of the lost causes that have been loosened with it. |
We use to use that method in the Army ACF-50, it works great. Plus side It's Cheap! My Farther and I used it when we restored our 1917 Model T. Bolts sized for over 75 years of sitting in a field in Nebraska, and it worked like a charm..
Life/time Saver.. |
PB blaster is better then what the test shows. I can contest. Not saying there are not better products out there but PB never let me down.
Owner of: cub 1650 cub 122 |
