Old 09-12-2013, 09:38 PM
moose007's Avatar
moose007 moose007 is offline
Default Replacing 125 drive shaft
Well I got my drive shaft today from rweaver. I started on it almost right away. It wasnt to hard to pull the rear end on the tractor but putting it back together was a bit more challenging. I had to get my wife out there to run the jack while I was lining everything back up. Got the shaft in place and the rear end bolted back up and in place. Tomorrow all I have to do to finish is the couple linkages and bolting the drive shaft to the rear end. I will post pictures of the drive shaft on here tomorrow when finished.
Thank you rweaver for helping me out with the drive shaft.
1967 IH Cub Cadet 125 w/ hydro lift, hydo option in front, 3 pt, and 38" deck
Old 09-12-2013, 10:00 PM
rusmart rusmart is offline
I'll be doing the same thing here in a bit. I got a 125 a few weeks ago. After I got it home, I noticed that someone put a bolt in the driveshaft where it slips into the flywheel cup. Probably didn't have the right part, and so they improvised. Now both the cup and the driveshaft have a lot of wear and need to be replaced soon.
Pics would be appreciated
Russell
Cub Cadet Original w/ 3pt
Cub Cadet Original w/ fenders, creeper, & 3pt
Cub 100 w/ 3pt
Cub 125 w/ 3pt
NF Blade, cultivator, brinly plow, 38" & 42" deck, disc, tiller
Old 09-15-2013, 12:04 AM
Joetotleben Joetotleben is offline
Talking
Well can I say me too lol! My 125's PO put a bolt in the front end also. Then WELDED all over it! I need to replace the whole deal now. Good luck guys.
Old 09-15-2013, 06:39 PM
Tim.E's Avatar
Tim.E Tim.E is offline
It seems like NF hydro's are the hardest to work on.My Dad has a 105,I am putting a new hydro fan on it.I pulled the hood,grill and engine off and winched up the front and stood it on it's rear wheels.I think it is a lot easier to work on this way.I can sit on a milk crate and work on the driveshaft.
Cub Cadet 100 "Super" (red) show tractor
Cub Cadet 100 show tractor.
Cub Cadet 100 worker
Cub Cadet 106 refurbished/modified (red/white)
Cub Cadet 128 "refurbished"
Cub Cadet 1450 my dedicated mowing tractor
Tractors awaiting refurbishment:100 with fenders,128,73 with creeper and fenders,106,122,147,126 with creeper.
100 w/pan seat and 3 point hitch
Tags
125, driveshaft
