Old 09-22-2013, 10:36 AM
Mainecubcadet108's Avatar
Mainecubcadet108 Mainecubcadet108 is offline
Default Governor weights sticking ????
Guys i have a question.We had a pull tonight and unloaded did our usual put weights on and weighed up and the tractor had a skip and found out the plug was junk.But what happened after is weird.We run 3 weight classes and missed the first one.We run 4000 rpm and when we pushed the throttle it would rev up like an open rpm motor..Checked all the usual things and come to the fact that the governor gear broke .Because i didn't feel any resistance like you should on the governor arm.So we thought.Loaded it on the trailer and was going to go home.Readjusted the governor arm per kohler specs and had only 2000 or less rpm's and the readjusted it and had open rpm's.But we did governor arm adjustment numerous times and had same results.Low rpm's or wide open.Then toke it apart again and my brother tapped the side of the block with a hammer and put back together and had 3850 rpm's.So we ran it and was fine.Next class moved governor spring and was back up to 4000 rpm's.But the whole time we adjusted the governor spring in different holes before governor adjustment and wouldn't make a difference.Could one of the weights have hung open.
Current tractor my son and i have
1991 wheelhorse 520h 60"deck 48"snow blower w/ onan 20 hp
1980 whelhorse b-82 need restore
1976 simplicity 7116 all restored waiting for a new motor (my sons tractor)
1967 sears super 12 (my sons tractor)
1972 Cub cadet 108 restored w/ complete motor rebuild 5 years ago
Old 09-22-2013, 06:52 PM
dvogtvpe's Avatar
dvogtvpe dvogtvpe is offline
I suppose its possible. I've never run into it. when its idling and you push the gov arm to the full throttle position you should feel it pushing back. same goes when you have it wide open and you push it to idle. it should push back. if its working correctly now you could get familiar with the feeling of it in case it acts up again
Old 09-22-2013, 07:02 PM
Just curious, do you have the current plastic governor gear installed or one of the old cast iron units?
Old 09-22-2013, 09:18 PM
Not sure on which one is in there because iv'e never been inisde this motor.It is a Kohler k241 10hp so it could have the metal one not sure.And as far as the resistance on the governor i know what to feel for and like i said it wasn't there and then it was.I don't know.We went from being on the trailer for the first class to getting a 2nd and a 3rd the next two classes.
