Old 10-03-2013, 08:22 AM
Blulakes Blulakes is offline
Default forward,reverse lever questions
Tractor is a 107 1970
2nd question. My forward and reverse lever on the dash moves kinda easy. So when it's moving the lever moves kinda easy also. SO I need to hold it still while holding it and the steering wheel. I looked underneath the tractor and seen a bit of linkage but not sure what needs replaced and or tightend up. I assume the lever should move to easy.
Here is a video
http://youtu.be/HtYJNIBkGa0
Old 10-03-2013, 08:44 AM
That is a Mule Drive Extension Spring
Get it from your local Cub dealer or contact our sponsors up at the top of the page, or place a want add here on the site.
Part Number: IH-489607-R4 Price $6.44
Old 10-03-2013, 08:52 AM
Thanks will defy hit them up on that. That takes care if first question
Old 10-03-2013, 09:14 AM
The tension adjustment for the Hydro Handle is in the Service Manual as found in our Technical Library Section.
Old 10-03-2013, 09:29 AM
Lightbulb
Thanks very much. Please don't feel like
I don't search. Just bit harder on a phone. Plus I have no idea what the smaller parts are called. This is my first tractor
Old 10-03-2013, 01:29 PM
The service manual def. will help. There is a nut inside the dash that needs to be tightened to make the hydro lever not flop like it is. Good luck.
Old 10-03-2013, 05:42 PM
bja105 bja105 is offline
An open end wrench, 1 1/16, cut to about 3 inches, will help you tighten the lever tension nut.
Old 10-04-2013, 02:25 PM
Ok thanks for info.
I found the pdf i needed.
I looked for the nut, but i dont see it.
Everything from the lever down is tight no play.
It seems to be in this area in the red circle
Old 10-04-2013, 03:26 PM
Ok I found this hidden adjustment nut lol.
Need to get to it now
Old 10-04-2013, 03:46 PM
Ok trying to remove the steering wheel, and the speed control lever.
I have the nut of the wheel abut wont budge.
The lever I have the screw backed all the way out but wont budge,
