Old 10-05-2013, 02:52 PM
digger350 digger350 is offline
Default 2086 odd brass dowel-collar???
I tore down my Cub Cadet 2086 with Kawasaki 20hp motor, replacing gaskets and such. It seems a brass dowel or collar fell out somewhere and I cant find any place that it would go. I've looked at motor diagrams to no avail. All the other dowels or collars are made of regular metal but this is brass It's giving me major headaches. I can't find anywhere this should go.
Old 10-05-2013, 04:23 PM
how about a pic.......
Old 10-06-2013, 10:19 AM
anybody know where this BRASS collar or dowel goes?seems like it fell out from somewhere when i took the crankcase cover off but i didnt notice from where it happenned so fast...the crankcase has 2 collars or dowels in it but they are steel and this is brass ...the other ones are steel and dont seem to be missing one anywhere...diagrams have been no help...
Old 10-06-2013, 11:31 AM
Do you have a service manual for this engine? It would seem like that should show it.
Old 10-06-2013, 11:49 AM
no have been looking at diagrams on partstree ...cant find anywhere that this would fit ..the block has 2...cylinders have 2 each...nothing seems to be missing
Old 10-06-2013, 12:36 PM
Just my nonprofessional opinion I would buy a service manual.
Old 10-06-2013, 01:13 PM
cubs-n-bxrs's Avatar
Looks to me like a stand off spacer for a fuel pump mounted on the shroud or a spacer that goes on the gov mechanism. Isn't there also a spacer like that on the air filter mounting bracket. Parts tree shows a collar like that under the gov/choke plate.
Old 10-06-2013, 01:52 PM
could be but i havent took the governor off and theres no plate around it just unhooked the springs
Old 10-06-2013, 11:12 PM
clint clint is offline
Looks like it's cadmium plated if parts tree or service manual give a list of parts maybe it will be noted that it's plated ?
Old 10-07-2013, 07:51 AM
Check that dowel with a magnet maybe it's not brass.
