Old 09-21-2013, 02:50 PM
Sawdust Sawdust is offline
That's a great idea...I would like to hear it run also.Thanks for sharing.
Old 10-15-2013, 10:32 AM
Dave R Dave R is offline
Default weed eater
I would think 1/8 inch steel aircraft guy cable would work great for the "string" It is exceptionally strong and should last a long while, and it is easy to work with. It is readily available at Lowes' etc. I may have to try this.
Dave in SW Missouri
Old 10-16-2013, 12:47 PM
Berwil's Avatar
Berwil Berwil is offline
I don't know if the aircraft cable would do all that great of a job. Most of the cutting happens at the tip. I would guess that after mowing a few minutes or after the first few rocks, the cable would fray at the ends and could give you an uneven cut.
Bill
Old 12-23-2014, 07:04 AM
oldyellow oldyellow is offline
Smile
Looks good to me.I appreciate your idea.
Will try it myself this summer. I try mowing in my woods with rocks,low stumps. Hard on mower bearings.I really believe if they work well,you could sell them!
Thanks and good luck
Tony
Old 12-25-2014, 10:05 PM
Moark Willy Moark Willy is offline
Wow
I would highly recommend staying away from aircraft cable. Any impact with a rock will most likely fray or break the cable and send needle-like shards airborn....into unsuspecting pets or children who just may be in the area.....or your own ankle.
Old 01-27-2015, 08:20 PM
fpatd's Avatar
fpatd fpatd is offline
Talking
Trimmer string works great for me , I've done this to a push mower , never thought about a rider ! may be go full custom & set every thing with rear steer & front drive kind of like a fork lift !
Old 01-30-2015, 10:32 AM
CubCadet129 CubCadet129 is offline
I guess that's a cool idea but it's gonna be a real pain changing out those strings.
Old 10-14-2020, 08:20 AM
sVincentS sVincentS is offline
I totally dig this idea. I've got more than enough mowing decks laying around. I'm gonna give it a go but I'm going the steel cable route. Will let y'all know how it goes. Thanks for this great idea.
'62 Original, '68 104
Old 04-23-2021, 08:42 AM
vtgunnut vtgunnut is offline
great idea, you should put a patent that!
Old 04-24-2021, 07:59 AM
Billy-O's Avatar
Billy-O Billy-O is offline
Should have thought about that 8 years ago when this thread was started.....
Kind of late now!?! Ever hear of Dr. Mower?
Plow blade
#2 Cart
QA36 snowthower
