Old 10-19-2013, 09:37 PM
Nice Chris
The seat spring support seems to be on upside down but if that's the only PO mod your in good shape
Old 10-19-2013, 10:03 PM
Looks great! Be careful with the battery being in the opposite way, almost looks like the hold down is dangerously close to positive lug on battery
Old 10-19-2013, 10:15 PM
Congrats on the 127, Chris!
johncub7172's Avatar
Thumbs up
Sure looks like a clean tractor, nice buy!
Old 10-20-2013, 06:18 PM
Sugarmaker's Avatar
The battery hold down is close to the terminals but does have clearance. There's a piece of cardboard in there too.
I was very surprised the screws in the foot rests came right out with a big screwdriver. Found the previous owners name and address scratched in the foot rest support.
Took the seat pan off to looks at the trunnion. Yes it needed repaired. So I cut a small strip of steel and MIG welded it in place. While off I pressure washed the hydro of accumulated grease and grime.
The shifter lever was very loose, So I made a crows foot tool and was able to sneak in and tighten the nut on the hydro lever. That was not easy but tightened the lever up a lot.
With the trunnion repaired and the lever tightened it seemed to do a good job holding in neutral.
Changed the oil. Removed and cleaned the deck, sharpened the blades. The baffle was toast so I removed what was left.
Tractor mows good, and had 14 volts at the battery when running. Repaired some wire ends, and general clean up.
Hope things are good out there. Will post some pictures if I get a chance.
Regards,
Chris
Casbohm Maple and Honey
www.mapleandhoney.com
Old 10-20-2013, 06:36 PM
Sugarmaker's Avatar
Nice Chris
Todd,
I have to go look at some other Cubs. You may be right about the seat pan being upside down.
Regards,
Chris
Old 10-20-2013, 07:00 PM
Todd,
Regards,
Chris
Mine on my 147 is on that way....
Old 10-20-2013, 08:01 PM
4SPEED's Avatar
4SPEED 4SPEED is offline
good buy on the 127
Doug
Original , 100 , 125 , 582
Old 10-21-2013, 07:54 PM
Sugarmaker's Avatar
Folks,
Glad to have another narrow frame Cub. Down side is, I really need some more room!!!
Todd,
My other 127 has the seat pan on the same way, with the lip up. Is that the part you are referring to?
Doug,
Good to hear from you.
John, Allen,
Thanks, Hope things are good in Cub land
Regards,
Chris
Old 10-21-2013, 08:47 PM
Todd,
Yes it is, never seen one "upside down"
Maybe all of mine are wrong
http://www.partstree.com/parts/?lc=c...&dn=0019900023
