Old 11-10-2013, 02:48 PM
drcjv's Avatar
drcjv drcjv is offline
Default 1572 over heating
My 1572 is running hot, needle is all the way to the right. Coolant level is good, screen is clean and I have top hose insulated over engine. Tractor has run fine for years now running hot. Any thoughts?
Charles________________________
1572 3pnt, rear PTO, 50" deck
1772 3pnt 50" deck, Brinly Plow, 54" Power angle plow
1872 3pnt, 44" deck, Brinly Plow, 54" Power Angle Plow
2072 3pnt 50" deck, Brinly Plow
2072 50" deck
Cub Cadet Tank 50 Zero Turn
Cub Cadet 33" Commercial Walk Behind
1953 Ih Cub with just about every implement
New Holland TC33D with Loader and Backhoe
Old 11-10-2013, 03:09 PM
Thermostat could be going bad or the inside of the radiator is plugged up.
Old 11-11-2013, 06:29 AM
j knight j knight is offline
Default 1572 overheating
When did the needle go all the way to the right?
As soon as your start the engine, or after you had been using the tractor.
Almost as soon as you start would probably indicate electrical problem in gauge or sending unit.
After running the tractor. Like Sam Mac said no coolant circulation. Bad thermostat, plugged radiator, bad pump, poor air flow.
Old 11-11-2013, 07:35 AM
drcjv's Avatar
Feeling silly had dead battery and over heating and missed broken altenator belt. I did look but in my defence I just had eye surgery last Wendesday so sight is a little off.Thanks for the input.
2072 50" deck
Old 11-11-2013, 07:37 AM
Hope you didn't over heat it.
Old 11-11-2013, 07:51 AM
Glad you found it!
Old 11-11-2013, 10:59 AM
Glad you found it!
X2!
Old 11-11-2013, 08:18 PM
dsmithjr's Avatar
dsmithjr dsmithjr is offline
Glad you found it. Post some pictures of the repair process.
Don Smith
Old 11-11-2013, 09:05 PM
drcjv's Avatar
Well I went from bad to worse. I got the belt on and now tractor won't start I got full tank of fuel, I cracked the fuel line at injector and got fuel. I have good battery cranks very well. When it cranks I get alot of white smoke and it sounds like it wants to start but it won't. The fuel shut off seems to be moving from end stop to end stop freely. The tractor ran fine when I pulled into the workshop to put the belt on but after belt was put on now it won't start. Again all your help is appreciated.
2072 50" deck
Old 11-12-2013, 11:56 AM
cubfan's Avatar
cubfan cubfan is offline
That's how my 18 wheeler cranks when its cold,a bunch of white smoke until it starts.Seems like the glow plugs aren't working.Put a heater of some sort around the engine and let it heat the engine.Not a diesel expert by any stretch of the imigination but hope it helps.
