Old 11-16-2013, 01:13 PM
Shrewcub's Avatar
Shrewcub Shrewcub is offline
No problem doing a 1572. I can make the adapters for the pump and the engine, the shaft is a simple deal. You will need to drill and tap the pump input shaft for the newer style pump drive adapter.
How much to make a set for my 2072? Although I may do a Command repower so I may only need the rear one.
Old 11-16-2013, 05:33 PM
For a 2072 $175.00 shaft and pump adapter. Same price if you decide to put a Command in it. They are different length.
Old 11-16-2013, 06:35 PM
chevy13045 chevy13045 is offline
Sam what do u get for a set of adaptors for my 1572?
Old 11-17-2013, 07:07 PM
gt383mag's Avatar
gt383mag gt383mag is offline
are those shafts the same as a 1862? lookin at gettin the whole tractor to pirate the power steering and driveshaft to update a 782D. saw one done on youtube and he used the hydro unit also because its splined
Old 11-17-2013, 07:52 PM
For a 1572, $275 for both adapters and the shaft.
Old 11-17-2013, 11:37 PM
Shrewcub's Avatar
Thanks Sam! I should have been more clear, how much to just make the adapters? I have a lathe at work and a couple good welders next door. I could probably make the adapters too, but with the time it would take measuring everything that I have yet to take apart, it would probably be cheaper to have your guy make them.
If I do a Command repower would a shaft from a 2084/2284 be the right length? Then all I would have to do is drill/tap the pump shaft
It is going to be some time until I tear into the 2072. I just want to get a ball park on what I will have in it. I have a pretty hefty order to place with Xtreme.
Old 11-18-2013, 06:25 AM
If you are going to do the shaft yourself, for a 2072 all you would need is the pump adapter, $100. If you do a command repower the 2084/2284 shaft should fit but you still need a pump adapter.
Old 11-23-2013, 02:01 PM
782Smoker 782Smoker is offline
How much for a 782d? I hate the old rag joints!
Old 11-23-2013, 05:57 PM
$275.00. You would need both adapters and the shaft.
Guys if any more of you want prices on this PM me. This is not the for sale section or the parts section. I'm not trying to be the go to drive shaft guy. That's why I tried to show you how to do it yourself.
Old 11-23-2013, 08:09 PM
cumminsmannow cumminsmannow is offline
im all about building this myself but have been waiting for an exact model number so I can look up the parts for the conversion on my 1512. the front rag joint is wobbling about 3/8" out of true. I figured i would make it myself but 200 series doesn't narrow it down enough.
part numbers would be even better but a model number would work too.
