Old 12-08-2013, 10:05 PM
EarlJ's Avatar
EarlJ EarlJ is offline
Default Got a free set of 26" tires
My buddy Vince O gave me a set of 26" ags today. They are check cracked and all but they are better than the turfs on my 104. Now my problem, these things are huge..so I believe I have to raise the fenders. I just don't know how much, so does anyone know how much they have to raise? I'd like to get them on there just for fun...
126 in surgery with weights, spring assist, 3 point and sleeve hitch
100 with woods finish mower and rear lift,
Nice 125 with super nice sweepster, 1782 Super Diesel,
1650,782D in surgery, 102 parts tractor..
3 Brinley plows, Brinley cultivators , rear scrape blade, front plows and custom built bedder attachment.
Old 12-08-2013, 10:12 PM
Why raise the fenders,lower the ground....
Up to 534 and counting...
Old 12-08-2013, 10:15 PM
LOL Lew!
Old 12-08-2013, 10:22 PM
EarlJ's Avatar
I tried that already, problem is every time I lower the ground so does the tractor so that don't work lol...
Old 12-08-2013, 10:33 PM
You can raise the fenders but be aware you will have to modify the footrest connections, and your shifter may hit the opening in the pan.Just my 2 ¢…
Old 12-08-2013, 10:36 PM
cubby102's Avatar
cubby102 cubby102 is offline
I had a set of 26x12x12s on my 102 I had more issues with the sidewalls rubbing then hitting the fender with tread. Just don't over inflate you should be ok
Old 12-08-2013, 10:48 PM
EarlJ's Avatar
I was looking at that tonight, not really wanting to do the work if I don't have too. If I can squeeze them under there without too much work I'd be a whole lot happier...
You didn't raise your fenders? Just ran lower pressure? That may work, I'm going to try and squeeze them under there without unbolting anything more than the lugs...
Old 12-09-2013, 01:16 AM
ajcombs's Avatar
ajcombs ajcombs is offline
Obviously you weren't doing it right! Change the side of the earth u on and it will work.
Old 12-09-2013, 01:52 AM
cubby102's Avatar
Yea I don't remember exactly which tires it was that I had but I had them filled with wwf and maybe 2-3 psi. They were close... real close maybe 1/16 from the fender but never noticed them hitting. Only rubbed the sidewall. They were also on some home made wide wheels
Old 12-09-2013, 06:19 AM
Pictures when you get them mounted Earl!
