Old 12-09-2013, 12:57 AM
Userj8670's Avatar
Default Steering wheel resto
Was just curious if anyone has done one. Mine is in good shape but could use a bit of refreshing. Also I have seen what those center caps can look like - any product out there to remove the yellowing?
Old 12-09-2013, 10:00 AM
fourinchdragslicks fourinchdragslicks is offline
you can use buffing compound on the caps, but it will not take all of it out, ususally, that yellowing is uv damage to the plastic, (think automotive headlights, you can buff them back to greatly improve them, but they will always maintain a bit of a haze) also to really do the best you can, you would need to do the inside of the cap as well, maybe with a dremel?
Old 12-09-2013, 10:12 AM
vartz04 vartz04 is offline
New caps are on eBay for like $20
Cub 104 Refurbed Sprinig of 2013
Aftermarket headlights, 3 point, Brinly Adapter, Spring Assist, 42" IH Blade, 42" Mower Deck, 42" Craftsman Grader Blade, 10" Brinly Plow, 6-12 ags and 22x9.50 turfs
Old 12-09-2013, 10:45 PM
Shrewcub's Avatar
Shrewcub Shrewcub is offline
http://www.ebay.com/itm/130923831222...84.m1438.l2649
I was thinking of getting one. Has anyone bought one? If so, how is the quality?
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1980 IH Cub Cadet 782 w/CH20
1966 IH Cub Cadet 102 w/K301
1961 IH Cub Cadet O
1967 IH Cub Cadet 102 & 122
JD 2155 w/ 175 loader
Old 12-10-2013, 03:13 AM
Userj8670's Avatar
Caps look good but unfortunately that cap design is different than the one needed for a 126
Old 03-27-2026, 06:01 PM
Sspargur Sspargur is offline
Default Remove the Steering wheel
My grandson and I are working on our 125. We are needing to remove the steering wheel. Would anyone have a suggestion how to remove it?
Old 04-01-2026, 08:14 PM
MUSKET MUSKET is offline
Mine wouldn't budge after days of penetrating oil I put the nut back on and left about half of it sticking above the end of the steering column put a smaller nut inside of it and took my air chisel with a punch in it. Placed it on the top of the steering column where I had the smaller nut placed inside the nut and let it hammer while pulling up on the steering wheel, popped tight off.
