Old 12-13-2013, 08:59 AM
OldAndInTheWay's Avatar
Default O original color for front rim?
When I bead blasted my front rims off of my O I found that the color at the bottom was Yellow. There was a white layer on top of the yellow. I have never seen a picture of a O with yellow front rims.
Any Ideas?
Old 12-13-2013, 09:05 AM
C5rider C5rider is offline
Hmmm.
That IS interesting. I've not heard of that before but my experience is limited. I'm sure someone will chime in with some enlightenment.
Perhaps an industrial model?
Old 12-13-2013, 10:21 AM
mmzullo mmzullo is offline
probably they where jd rims. about 4 or 5 years ago someone was selling brinly wheels that was an exact match to the cub wheels. you just had to change the bearings. I must have bought about 20 sets or more. I'm down to 2 . They came with tires also. They where cheap(price wise) They had the correct carlise straight rib replacement tires for the wide tires on the wf and nf cubs.
Do the wheels have grease fittings?
Old 12-13-2013, 01:33 PM
I believe these are the original rims for the O. The front tires were also original I believe. They were tough to get off but my mini tire changer did the trick. I don't know how I would have done it without it.
Old 12-13-2013, 07:15 PM
I never have seen yellow rims on an O. They where not original. They could have been put years ago.
Old 12-13-2013, 10:43 PM
gmbadgley gmbadgley is offline
It's possible that it could be a primer coat, or it was sent down the yellow paint line first then painted white.
"If I can't fix it, I can screw it up so bad no one else can either"
Old 12-13-2013, 11:04 PM
Calvins66Cub's Avatar
I like your reply ending. Mine is, " If I can't fix it it's broke "
I like yours too. I might "borrow" it.
1966__122 Cub Cadet.
Owner: Calvin, 6 yrs old
Dad: Craig
Old 12-14-2013, 07:53 AM
Both rims had the tube rusted to the rim and one had bad rust around the hole where the valve stem goes. I cleaned it up and using body work methods I put new metal where the old valve hole used to be and drilled a new hole opposite. Sanded and primed and now it is ready for it's new coat of paint.
Old 12-14-2013, 08:04 AM
Here is a copy of the 1961 Cub Cadet Sales Brochure...
Old 12-14-2013, 03:23 PM
I'm thinking it was a fluke. Gonna go with white.
Interesting to see the front plate below grill is white...
Mine was painted yellow.. Like this one:
Looks like I will have to repaint it.
