Old 11-29-2013, 09:21 PM
C5rider C5rider is offline
yup,
It's officially apart!
Good luck! Ya know, it might be interesting when you're all done with the project to have a photo of all the parts that either needed replaced, or were just too far gone to use. Trying to use as much as possible seems to be the underlying thread here, so it would be interesting to see how small of a pile of "leftovers" you might actually have when finished. Just a thought.
Yeah, I'd say this one is on the long-term rebuild cycle.
Thanks for the update
Old 11-29-2013, 09:26 PM
johncub7172's Avatar
Thumbs up Well,.....
Looks like you are well on your way, and clearly know a lot more than me! I'm all eyes and ears! Looking good, a complete tear down! Thanks for sharing
Old 11-29-2013, 09:30 PM
Nixon327 Nixon327 is offline
This is a first for me. I've never torn down a transmission and rearend before. It will be scary to see the pile of parts left over.
Cub Cadet model 70
Cub Cadet Model 109
Definitely a work in progress!
Old 11-29-2013, 09:44 PM
Originally Posted by Nixon327 View Post
Well. I tore down the rest of the transmission. The needle bearing that the main shaft rides on is toast and gouged the shaft. I wonder if I can mill that down and run a little bit bigger bearing. Maybe that would be easier then trying to find a new shaft. I'm thinking that I should go ahead and replace all of the bearings. They are 50 years old. Definitely wouldn't hurt. Let me know what you guys think.
You've been busy! Keep the updates and pics coming.
Old 11-29-2013, 09:52 PM
Should I try and find a new shaft or mill that one down and install a new bearing with the new size.?
Cub Cadet model 70
Cub Cadet Model 109
Old 11-30-2013, 08:19 PM
cjrolke cjrolke is offline
personally I would find a correct shaft or a spare trans or....... a spare tractor
Old 11-30-2013, 09:06 PM
Thumbs up
I have always bought parts that would be the direct replacement for the bad part. A sure bet is buying another shaft and replacing the bad shaft. That much I know. Just trying to help!
Old 12-01-2013, 06:59 AM
Thanks guys I will try and find a new shaft.
Cub Cadet model 70
Cub Cadet Model 109
Old 12-13-2013, 10:07 AM
bluesman bluesman is offline
Talking Rear wheels
I would really like to know what those rear wheels came off of. They look like American Mags from the late 50's, the ones you'd see at the drag strip. They look great with those ags on them.
Old 12-14-2013, 02:06 AM
Rdrnek Rdrnek is offline
If you are talking about the reduction housing input shaft (the one that the drive shaft couples to you can find on on fleabay cheap enough that little needle bearing cup that it rides in is like $50 though
-Bob-
149 w/48"deck, 2 100s and and 2 ugly "O"s parts 104
