Old 12-13-2013, 12:14 PM
1811woody's Avatar
Default What snow blade will fit the 1863 ?
I'm looking for a snow blade for my 1863 not that I need it but hey its a cub thing. My question to you is what model will fit and was power angle available?
Old 12-13-2013, 12:50 PM
Go to the Cub parts site, type in 1863, hit go, click on the serial number, click on attachments and you should find what fits.
Old 12-13-2013, 01:39 PM
Captain B Captain B is offline
As SamMac said, this will give you lots of info. You just need the model and serial number.
http://www.cubparts.com/oemparts#
Old 12-13-2013, 01:49 PM
1811woody's Avatar
FYI. So far its a 316 (190-316-100) mounting. It depends on the blade width for a different number
Old 12-13-2013, 02:30 PM
I'm pretty sure the old regular wide frame blade will fit it. Someone correct me if you've tried and it doesn't work, but I was thinking I had one on dad's 1864....
Old 12-13-2013, 03:12 PM
1811woody's Avatar
I did wonder about that, I was less sure about the lift mechanism
Old 12-13-2013, 03:25 PM
You might be right about that..... I can't remember. I know we kept the blade from the 782 when he traded, but can't remember if we tried and it didn't work, or if we used it on the tractor. Still have both, but just don't recall.
Old 12-14-2013, 07:23 AM
spudder spudder is offline
Woody, I have one that came off a 1864. I'm not sure what number it is. Why don't you make a trip down to my place and look at it. While you're here I'll show you my Supers.
You might just go home with some Cub Cadet Christmas presents for your wife!
I just looked up the numbers for the snow blade for a 1864. The 42" blade number is 190-375 and uses blade adapter 190-316. I think you can cross reference these numbers on partstree to see what models used these same items.
Old 12-14-2013, 09:00 AM
rweaver rweaver is offline
the blade is the same the snowblade mount is not your 1863 has the high axle mount blade if you use the low axle mount on a high axle tractor the blade will be leaned way front
