Old 03-06-2014, 12:14 PM
C5rider C5rider is offline
Originally Posted by gsomersjr View Post
That 12' cut might be good for open ground but if the church has a cemetery?!
gsomers, you owe me a new keyboard!
Old 03-06-2014, 12:50 PM
Received a message from the seller. Turns out the PTO clutch is inoperable. Not sure if it's a broken part or ? I'll go through the parts manuals and see how it all goes together so I'll have an idea as to what it SHOULD look like.
I hear there's big $ in fixing a clutch. Would anyone care to put a decimal to that dollar sign? How much does it take (usually) to fix a clutch in one of these things. I'm hoping to get the tractor for under $800. Would a clutch double the cost? I'd do the work myself, but I can't manufacture parts!
thanks!
Old 03-06-2014, 12:58 PM
I think J-Mech mentioned he has done the clutch's in those, you may want to PM him.
Old 03-06-2014, 01:00 PM
jimbob200521's Avatar
thanks!
TAKE THIS WITH A GRAIN OF SALT AS I'M NOT 100% SURE THIS IS WHAT YOU NEED!
But this is what appears to be a new PTO clutch assembly from Ebay for about $400. The guys got good feedback so maybe someone else from here that has more experience working on them can comment but if memory serves, this should be the whole, correct assembly.
http://www.ebay.com/itm/NEW-POWER-TA...-/281275833409
-Ryan
Old 03-06-2014, 01:45 PM
Thanks JimBob!
That helps me understand a little better also. AND, the same seller has this rebuild kit, so if everything is there and rebuildable, I could go that route also. So long as the tractor moves around and only the PTO is bad, this still seems quite viable.
Already downloaded a manual for the tractor directly from MTD, so I've got a little more info. The manual takes a while to download, but it's worth it!
Old 03-06-2014, 02:18 PM
If your rebuild it yourself, get the parts from here. I use them a lot and as you see, prices are good. The one jimbob posted a link to on e-bay looks like a very good deal for the $$. Probably the quickest and easiest option.
Thanks for the link to that service manual too! I didn't have that one in book or PDF format! SWEET!
Old 03-06-2014, 02:49 PM
CNeubauer CNeubauer is offline
We had a 185 for a few years, the good is that if you think a Cub Cadet is built tough a lo - boy is even tougher. For mowing wide open areas it will work Ok but don't let the grass get too tall or power will be a problem. With sharp blades and grass not too tall I could mow in 2nd gear and do a good job but probably did more mowing in 1st than 2nd. For mowing my 2162 with 60" haban deck is twice the mower the 185 was.
Old 03-06-2014, 04:18 PM
What is a 2162?
Old 03-06-2014, 04:28 PM
2182 but my phone seems to think it should be a 2162.
Old 03-06-2014, 07:48 PM
Pauld Pauld is offline
I own two 154's,one for 15 yrs with a snowplow and the other one with a front end loader for a year and I have never had any problems with the clutch or pto,if the one you are looking at has the rear 3 pth,dual breaks,mower deck and runs good $800 is a good deal and worth fixing.
102 ,129 ,149 ,169 ,154, tiller .chipper
wide frames rule
