Old 03-11-2014, 12:07 PM
cameraman611 cameraman611 is offline
Default Quietline Motor Mounts
Hi All: Anyone have a quick and easy way to determine condition of motor mounts on 1650 & 1200?
Old 03-11-2014, 12:31 PM
jimbob200521's Avatar
....look at them? you should be able to crawl under the tractor and get a visual of them. If they're smashed, they need replaced. Otherwise, pull the motor.
-Ryan
Old 03-11-2014, 01:51 PM
If they are really bad, you will most likely find the engine rails sitting on the axle cross member!
Old 03-11-2014, 01:53 PM
If they are bad, you will also more than likely be replacing some driveshaft bushings front and rear.
Old 03-11-2014, 02:14 PM
Here are some links that will help you with your QL.
Quiet Line Links:
Download and print all the manuals;
Carb Rebuilding: http://mgonitzke.net16.net/tools/carb_rebuild.pdf
ISO mount and snubber: http://www.onlycubcadets.net/forum/showthread.php?t=7
Hydro Filters: http://www.onlycubcadets.net/forum/showthread.php?t=12
Ignition Circuit: http://www.onlycubcadets.net/forum/showthread.php?t=27
Ignition Coil: http://www.onlycubcadets.net/forum/showthread.php?t=11
Spark Plug Chart: Use Autolite: http://www.onlycubcadets.net/forum/s...ead.php?t=4638
Static Timing for new points: http://mgonitzke.net16.net/tools/static_timing.pdf
Chassis Service Manual: http://www.onlycubcadets.net/forum/s...ead.php?t=4644
Kohler Service Manual: http://www.onlycubcadets.net/forum/s...ead.php?t=4646
1650 Operators Manual: http://www.onlycubcadets.net/forum/s...ead.php?t=4670
PTO adjustment: http://www.onlycubcadets.net/forum/showthread.php?t=30
Wiring Diagrams: http://www.onlycubcadets.net/forum/showthread.php?t=22
Cradle Mod: http://www.onlycubcadets.net/forum/s...ead.php?t=4630
Old 03-11-2014, 02:21 PM
IH Cub Cadet IH Cub Cadet is offline
A good indication is if you can just grab the engine and rock it side to side.
Thanks!
Bill
IH Cub Cadet 109
IH Cub Cadet 126 (2)
IH Cub Cadet 149
IH Cub Cadet 1650
MTD Cub Cadet LTX1042
Old 03-15-2014, 11:41 AM
cameraman1650 cameraman1650 is offline
Default motor mounts
Thanks to everyone for their help, especially Mr. Wayne. I was unable to log back on for some reason and could get no response from webmaster. So... now I'm cameraman1650. Thanks again, Case
Old 03-15-2014, 02:06 PM
If you decide to replace the rubber mounts with solid steel ones, I sell them for $40 shipped ( USA )
just the motor mounts
http://www.onlycubcadets.net/forum/s...26&postcount=5
all my parts
http://www.onlycubcadets.net/forum/s...ad.php?t=20875
Old 03-15-2014, 05:48 PM
all my parts
Not that this question hasn't been asked 1000000000x times over, but as someone who sells the solid mounts, do you have much feedback from people that don't use them on pullers as far as vibration? Such as vibration compared to previous models or models after? I just spent the day installing new rubbers up front (the "bumpers" as I call them, not the mounts) as well as "tweaking" the mounts and I still get a good amount of vibration. Granted, these aren't actual Cub Cadet mounts, but they are close enough. Just figured the "Quiet"lines would be smoother and quieter, maybe it's just me. I've debated going solid mounts, just hate to spend the money if it's not going to get any better.
-Ryan
Old 03-15-2014, 06:42 PM
I can't compared a rubber mounted engine since I have narrow frames which are all solid mounts.
Everyone who has purchased their solid mounts have been happy but I can assumed they knew what they were getting with the purchase.
