Old 03-25-2014, 10:05 PM
IHinIN IHinIN is offline
Default Blast cabinet dust collector
I have been using a shop vac as a dust collector on my blast cabinet. It works fairly well but after a while the filter gets plugged and it loses suction. I was looking at different styles of homemade dust collectors online and I decided to make a cheap cyclone style. I used a 5 gal bucket and a few pvc fittings. The inlet from the cabinet enters at an angle to direct the dust against the wall of the bucket where it swirls around and drops out of the air. It seems to work good considering it took about 10 minutes and $11 to build.
Old 03-25-2014, 10:21 PM
That's pretty neat, Adam!
Old 03-25-2014, 10:38 PM
gt383mag's Avatar
gt383mag gt383mag is offline
how well does it work at my bros we put the filter bags in the shop vac and the work pretty well
Old 03-25-2014, 11:43 PM
Very interesting!!
My tractor has an air filter that works the same way.
Consider setting a 3 gallon bucket inside your blue bucket, making the air swirl a little further, that is what this tractor has.
Old 03-26-2014, 12:56 PM
gt383mag's Avatar
Very interesting!!
very cool tractor im jealous
Old 03-29-2014, 09:20 PM
john hall's Avatar
Wonder about taking the entire air cleaner assembly off a piece of ag or industrial equipment. Get one of the vertical styles that has the large dust collector bowl on the bottom. The air filter already has the fins on it.
Old 07-01-2014, 01:51 PM
sawdustdad's Avatar
That's a great idea. I have the same blast cabinet, and use a shop vac hooked up directly. Will have to try this cyclone idea. Thanks for sharing. Come to think of it, I have the exact same thing (30gal trash can) between my woodworking planer and the shop's dust collector.
