Old 03-28-2014, 09:07 AM
drcjv's Avatar
drcjv drcjv is offline
Default What would you carry
My 1772 has a tool box on the back. Whith the limited space what would you carry. I am thinking 3/4 wrench for 3pnt, 15/16 wrench for 3pnt plow. Extra hair pins and hitch pins. I would like to carry a hammer but any one that would fit is not really big enough to be of any help. Any ideas on what might work as hammer and also fit.
Charles________________________
1572 3pnt, rear PTO, 50" deck
1772 3pnt 50" deck, Brinly Plow, 54" Power angle plow
1872 3pnt, 44" deck, Brinly Plow, 54" Power Angle Plow
2072 3pnt 50" deck, Brinly Plow
2072 50" deck
Cub Cadet Tank 50 Zero Turn
Cub Cadet 33" Commercial Walk Behind
1953 Ih Cub with just about every implement
New Holland TC33D with Loader and Backhoe
Old 03-28-2014, 09:13 AM
mmzullo mmzullo is offline
Cresent wrench. Then you can have any size wrench you need. Roll of small wire and cutting pliers. Wrap it in a tight cloth, or it will sound like a sewing machine when you drive around. Cloth can be used as a rag.
Old 03-28-2014, 09:30 AM
Will it hold a couple cold beers? LMAO
Old 03-28-2014, 10:21 AM
jimbob200521's Avatar
This
I'd keep a good pair of pliers, some wire, a crescent wrench, a couple extra cotter pins, and a hitch pin. Should be a pretty good start, I know a lot of hard times have been fixed with some wire, a crescent wrench, and a pair of pliers in the field.
-Ryan
Old 03-28-2014, 10:29 AM
andyw's Avatar
andyw andyw is offline
If your yard is anything like mine in the spring a pull strap would be nice to have on hand. I always seems to search for 1/2 an hour when I need one.
btw, Im stealing this idea and putting a tool box there as well, very handy.
1772 undergoing some updating.
Old 03-28-2014, 10:42 AM
Xtreme is selling them
Cub Cadet Tool Box CC-54-002 $60.00
Finally a bolt on tool box for your Quietline, Wideframe, 82 Series, 72 Series and others that use the Wideframe series fenders Bolts on using the existing fender mount bolts. Ships unpainted.
Old 03-28-2014, 10:57 AM
Since the tractor is a 1772, I would carry a 17!
It would be helpful, if you go places like this;
But, I do not have room for such a box,,,,,,,,,
Old 03-28-2014, 11:01 AM
gsomersjr's Avatar
gsomersjr gsomersjr is offline
If I had a tool box I think I'd carry just the tools needed to operate the tractor, like the wrenches for the hitch and a couple bottles of water (for me). My luck I'd never have the right tool with me if something broke anyway and if it did break it's only a couple hundred feet at most to my real toolbox. If you're mowing more than 4 or 5 acres it might be a different story.
Current: 102 122 SZ60
Past: Original 71 72 73 86 100 102 122 123 124 125 127 129 147 149 169 383 582 682 782 782D 784 982 1000 1050 1100 1200 1204 1210 1250 1282 1415 1420 1440 1450 1535 1541 1641 1650 1710 1711 1730 1806 1810 1811 1860 1861 1862 1863 1864 1882 3185 3200 3205 7265
Old 03-28-2014, 11:16 AM
I can't believe CAD is getting that nice super dirty...lol! Just picking on ya, CAD.
Old 03-28-2014, 11:37 AM
Gotta run what I brung!
My normal "tool box" is that yellow trailer hooked to the hitch!
