Old 04-28-2014, 09:48 PM
slefkay slefkay is offline
Default NF spring assist
I spent about $20 dollars but I already had the piece of angle iron. I got a small clevis and hooked it to the lift arm to attach the spring. The angle is mounted to a bolt on the rear and a 5/16 eyebolt at least 6 inches long, hooked to the spring and through the bracket. Tighten the eyebolt adjust the tension.
All parts came from tractor supply.
2 inch angle, 1 inch wide
The spring is the heaviest duty 1 inch X (about)10 inch spring I could find.
2 5/16 nuts and washers
clevis has 3/8 stamped on it,its about 2" long by 1 1/2" wide.
Scott
Old 04-29-2014, 12:02 AM
Nice job on the spring assist.
Old 04-29-2014, 01:38 AM
If it works for you, it works for me
Good thinking.
