Old 05-18-2014, 09:42 AM
dbuck dbuck is offline
Smile K321 ?
Has anyone converted a K321 to a gear drive starter from the S/G. If so will the gear drive starter bolt on where the S/G bolts? This engine is in a CC149. Thank you for your time.
Old 05-18-2014, 09:47 AM
dvogtvpe's Avatar
dvogtvpe dvogtvpe is offline
yes it does. as long as your block has the scallop above the mount pad for the starter. pretty sure all the 14 blocks did, I know not all the 10's and 12's did
Old 05-19-2014, 09:35 AM
Smile
Thank you for your reply, I will check the block and if the scallop is there, I will have to gather up some parts.
Old 05-19-2014, 10:04 AM
OffTime's Avatar
OffTime OffTime is offline
My K301 in my 129 was converted. Just so you know, the front bearing plate, flywheel and tins also have to be changed. The flywheel with the ring gear is larger diameter, so the tins have to be larger to accommodate. The bearing plate has to be changed so that you have the bolt bosses to fasten the stator.
Matthew B
1972 129 w/hydraulic lift and head light option soon to be repainted
Old 05-19-2014, 06:05 PM
dvogtvpe's Avatar
14 already has the larger bearing plate. might not have the cut out for the starter. I know the shroud don't have the hump needed
Old 05-19-2014, 11:04 PM
OffTime's Avatar
I'm not sure that the bearing plate has the bosses drilled and tapped for the stator.
Matthew B
Old 05-20-2014, 09:14 AM
Smile
Thank you Guys for your replies. I have a few jobs in the shop to get out before under taking this project. I am not interested in going the stator route, If possible it will stay battery ignition. Does anybody know if the flywheel has the indentation for the ring gear? There is no pop out for the gear starter on the shroud, so that being was there any difference in the overall dia. between the gear starter and the S/G flywheel shrouds? Thank you for your time.
Old 05-20-2014, 10:42 AM
The stator isn't for the ignition, it's for charging. You can't run a starter AND a generator. The starter mounts where the generator does. You have to run a stator.
Old 05-20-2014, 11:45 AM
Smile
You are correct, I do not know what I was thinking. If I can get it worked out, I am going to run a small alternator.
Old 05-20-2014, 11:48 AM
Unless your looking for more amperage, a stator is an alternator. They cost less too. (Assuming that you have an engine to pull parts from.) Only real benefit of an external alternator is increased amperage, and if you use a small one, (like what the kubota's use) you aren't really gaining anything. I'd go with the stator. Just my
