Old 07-26-2014, 02:21 PM
Should have put grease on all that before closing it up.......
Old 07-26-2014, 02:53 PM
yeeter yeeter is offline
Its not closed. Just stuck together for photo purposes (and for my own inventory of what parts are missing...). Need a seal and a gasket, then will grease and put together permanently.
Old 07-26-2014, 09:14 PM
I wouldn't bother with the cork gasket. I'd silicone the two halves together.
Old 08-15-2014, 07:22 AM
This project continues at its own pace.... (there was a reason I started in July!!)
What gearbox grease is acceptable. There is a cub cadet brand listed on the parts list, but I was more interested in something I could pick up at NAPA....
Old 08-15-2014, 09:23 AM
Is there a way to grease these after they are assembled? If not I'd put a grease fitting in it some place. Just my 2 cents.
Old 08-15-2014, 05:53 PM
Yes, there is a plug at the top of the housing. Regular grease from a grease gun seemed too thick to me (rotating gears), but i don't know.... Will lookup the description on the cub cadet recommended and see what it is.
Old 08-15-2014, 06:05 PM
Not really a sealed box. I'm with Sam.
As a side note, I have one apart that I have to get back together before winter. I'm adding a zerk and intend to grease it regularly. The plug in the top is vented, so the grease should come out of it, but honestly, I think no better than the seals are, it will ooze out the seals too. Just my
Old 08-15-2014, 06:32 PM
calls for this stuff:
http://www.epc.shell.com/Docs/GPCDOC...80762_1669.pdf
Im not sure how the viscosity compares to whats in my grease gun.
I agree the gear box doesnt seem sealed that tight. The plug is at the top and I cant see any issues pumping grease into it. A zerk doesnt hurt I guess, but not sure it matters on this one.
Now there are bushings at each end of the auger. I was wondering if I could cross drill some zerk fittings into these. Otherwise running on whatever residual oil/grease I can get to stay in there.
Old 08-15-2014, 06:39 PM
For what ever it's worth I used to own a Yamaha snow blower that ran 140W gear oil in the box. I don't see why that wouldn't work in one of these or maybe out board motor lower unit lube.
Old 08-16-2014, 05:12 AM
sbauerz28's Avatar
I used regular hi temp synthetic wheel bearing grease with a little Royal Purple gear oil mixed in just because I had some left over. Right or wrong thats what I did and never had a problem last year. You put the grease in before you assemble the case halves.
