Go Back   Only Cub Cadets > Resources > Technical Library - Tractors > Technical Tips
Closed Thread
Old 07-29-2014, 12:06 AM
Okay, I'm back. I called around on the oil seals and found that Motion Industries had them in stock but not the ones I posted, those are NLA but they had another brand so I ordered them. I purchased 6 seals for a total of $48 shipped to my door. I pulled all the old seals and cleaned everything up.
The roller bearings looked okay for not having any grease in them. What was in there was all dried up and nasty so I cleaned them with degreaser and brake cleaner then repacked them with wheel bearing grease after the seals were installed.
The roller bearings are HK 3020 if you ever need to replace them. I pressed one of them out just to see how hard it was and they come out pretty easy.
Here is a shot of the new seals installed with the roller bearing block nearest.
Time to button it up. The only place I used Permatex was at the top and bottom of the inner bearing block. I used Ultra Black.
Old 07-29-2014, 12:21 AM
Time to start stacking parts. There are two gaskets, a rear axle cover plate and the differential cover. I used two 1/4-20 bolts and cut the heads off to make reassembly easier.
Cub Cadet wants $25 for each gasket. I was careful when I removed them and I reused the old ones after I cleaned them up. They can be reused, I have no leaks. They have some type of metal in them so they are pretty tough.
Here is the inside of the rear axle cover plate. The unpainted pieces are some type of spacer plate they use to compensate for the gasket that goes between it and the aluminum rear housing.
That's all the pictures I have. All in all, it wasn't a hard job and so far everything works great.
Old 07-29-2014, 08:49 AM
Outstanding write up on the repair. First time I've seen one of these apart. I'll stick to the older stuff thank you. Can't believe that they didn't design it so that the outer bearings could be greased. This thread will be going in the tech section.
Old 07-29-2014, 01:06 PM
timbo2's Avatar
timbo2 timbo2 is offline
"I don't have a socket big enough but I will next time."
I'm glad I'm not the only one using old pipe and 1/2 " socket wrench to make a breaker bar the few times I need it.
Nice work!
- Tim
Closed Thread
