Old 07-10-2013, 11:02 AM
Zak62592 Zak62592 is offline
Default CH-18's Broken rocker arm bolt
Received a 2186 for free, previous owner said there was no compression. Assuming it was the head gasket I started the tear down. Upon removing the valve cover I saw that one of the rockers, pushrod, and bolt were all out of place.
Upon further inspection, I realize the bolt was sheared right off!
No idea how to get that thing out. I also don't want to spend abotu $120 for a new head. Help?? Much thanks
Old 07-10-2013, 12:07 PM
jmroy's Avatar
jmroy jmroy is offline
Use a bolt extractor or get a used head.
Web Developer - Need a website? Contact me.
Old 07-10-2013, 03:19 PM
It's probably not in there tight. Left handed drill bit will probably pull it out without having to use an extractor.
Old 07-11-2013, 06:55 AM
1982flh 1982flh is offline
Common problem with this engine as stated before a screw extractor or left hand drill (should) bring it out and $1.50 metric bolt from Kohler dealer, make sure of torque spec. for this bolt when replacing
Old 09-01-2014, 12:52 AM
Old Cub Cadet Old Cub Cadet is offline
Default CH-18 Rocker Arm Bolt Snapped
You mentioned that this is a common problem with the CH-18. What causes this and what is the solution?
I have a CH-18 that broke a rocker arm bolt. Got an easy out to get it out and replaced. Ran for about 10 minutes and now it's broken one on the other side! Uhhhh!
I'm afraid it's deeper than just taking the rocker cover off and replacing a broken screw. It would be nice if that's all, but I fear the worst!
1450 & 1650
Old 09-01-2014, 10:10 AM
dvogtvpe's Avatar
dvogtvpe dvogtvpe is offline
I would have just replaced all 4 at the same time. its a known problem. they all have the same amount of run time on them and the cost isn't that great
Old 09-01-2014, 10:45 AM
cubs-n-bxrs's Avatar
A good prickpunch and a small hammer you can probably tap that broken stud out.
