Old 09-13-2014, 08:13 PM
alleycat alleycat is offline
Default 149 Trans and brake issues
Just got a 149 having a heck of a time with brakes/transmission set up can any one help. If engine is not running brakes work great, once engine runs brakes don't work at all.
Old 09-13-2014, 10:08 PM
That doesn't make any sense. The engine has nothing to do with a mechanical brake. I'd say the hrdrostat needs the linkage set so that it goes to neutral when the brake is set.
On another note..... what were you doing with it that you found this out? Just trying to use the parking brake? Or were you trying to drive it using the brake like a clutch?
Old 09-13-2014, 10:45 PM
Merk Merk is offline
I agree with J-Mech. The linkage needs adjusted or you need to repair the trunion.
There is a service chassis service manual in the tech section you can download or you can buy a paper copy from Binder Books.
Project Uncle Dick
Cub Cadet 70
Old 09-14-2014, 08:45 AM
Default brake
It has driven me nuts, yes I used the manual, however, I just read a post and I will try that, I don't believe I had it in neutral when setting brakes, I will make sure of that. I agree the brakes should not have anything to do with transmission running, I'm not used to having a clutch, brake and all with brake pedal. Thanks for your help
What the heck is the trunion??
Old 09-14-2014, 09:23 AM
chris hall's Avatar
chris hall chris hall is offline
do some research on youtube. just type in trunnion repair or cub cadet trunnion repair. i look at youtube all the time when i cant figure out something.your trunnion will be on the left side of the pump.if you have a wide frame its alittle easier to get to. this is a great forum and these guys can really help you. good luck.
105(sold)782x3 &124(sold) . Lawn sweeper yard cart. Homemade 3 point hitch narrow frame sleeve hitch spring assist ih snowplows . Rear weight bracket and suitcase weights.Lots of extra parts 😀.
