I haven't used them yet, but it was a direct replacement. They were designed for the polaris 2 seater atv with blades much larger than the 42 on the cubs. And they are supposed to be hardened steel. They should last a long time since they also spread the blade weight out over a larger area vs the factory cub shoes. I bought mine locally to save shipping. You might be able to find them online with free shipping too.
Thanks for this. They are $25+ (for 1) from CC. (but at least they aren't NLA)
Daniel G. . (May 1970) 147 w/an IH spring assist, 48" deck, 42" blade, 1969 73, #2 trailer, 10" Brinly plow and (on loan) Dad's #2 tiller. |
I've got mine mounted and have used them once. They are a lot better then what was on there, I just had flat shoes as you know don't work well in gravel. The new ones overall seem to be pretty stout and did a good job. The only thing I thought may be an issue was if you have it adjusted so there are a lot of threads hanging out on the shoe side of your bracket then theres a potential for them to get bent? I say that because theres only a half inch bolt that I think may bend if you catch something solid.
I would think that they would work pretty good because of their size. If the exposed shaft causes a problem then shim the shaft with large washers.
I just bought a set of the polaris ATV shoes for a new 42 inch blade I just picked up. Dropped the blade off at the sandblast shop this morning. Should get it back in a week or two, primed and ready for IH white paint.
+1 I was thinking along those lines also
bumping this thread because I bought some today.
I found a Polaris dealer local and called them about the parts. They were able to order some for me. At 15 dollars a piece, (they come as a pair) I thought they were a bit pricey. They do look like they are going to work better than the worn out originals. I'll get them mounted and probably painted up to blend in better.
$19.99 on Flea Bay
Polaris 2873423 SUPER HEAVY-DUTY SKID SHOES http://www.ebay.com/itm/like/390934970557?lpid=82
this is what happens when I try to support the local businesses. At least I know returns will be easier if need be; I can just drive 10 min. to the place.
