Old 10-05-2014, 04:34 PM
bocephus1991's Avatar
Default Does this look timed correctly?
Does this look timed correctly ? It does to me was wanting a second opinion. Thanks
Brian
Old 10-05-2014, 04:55 PM
dvogtvpe's Avatar
dvogtvpe dvogtvpe is offline
maybe its the angle but the teeth aren't meshing?
Old 10-05-2014, 04:57 PM
dvogtvpe's Avatar
looks like 2 teeth are damaged
Old 10-05-2014, 04:59 PM
It's the angle . I haven't installed it all the way. The teeth are fine. So you think it's timed correctly?
Brian
Old 10-05-2014, 05:04 PM
dvogtvpe's Avatar
to me it looks half a tooth off
Old 10-05-2014, 05:14 PM
If you turn it one tooth clockwise it looks one tooth off and if you turn it counter clockwise from the pic doesn't look right either. Mad at myself for forgetting to mark it exactly wasn't worry cause I knew there were timing marks on the crank an cam. Wish they marked these better from factory! This looks correct here's another pic.
Brian
Old 10-05-2014, 06:01 PM
dvogtvpe's Avatar
that's good.
Old 10-05-2014, 06:56 PM
Thanks for your input Don!
Brian
