Was wondering if I should use the float lock out pin on my 1650 with the rear tiller or not. Would it even make a differance since the tiller floats on the lift chains anyway. Someone told me the float lock out was for front and rear blades and plow.
The lock out pin is not needed when you use a tiller. It won't cause any problems if you have it in your Cub.
I don't use the lock out pin when I use my front or rear blade. That is a good way to break a pin in the lift system. If you have the correct arms on your sleeve hitch adapter and your plow is set right you don't need lock out pin to plow. |
