#21
SaturnV: You need to comply with the Cub Cadet Service Bulletin CC-106, Dated Feb 9, 1987. It's about cold weather cranking for the 882 (782D/1512, etc.). You have to add a second ground cable...
Email me at cubcadet@windstream.net & I'll send you a Hi-Res copy of the bulletin...
Myron B East Texas Most of of the fleet: Cub Cadets: 2 Orig,70,71,122,123,104,124,126,86,128, 109,800,1200,1250,1450,1650,IH 682,782D,IH 982. Cadets: 76,SO76,80,81,IH 182. RER: 60,75. Elec 95. Trailers: #2, #3, #4, 1200-A,1200-B,1200-C, 2000. IH 1210 P/U, an IH Scout II and an IH Scout 800 to tow 'em with. |
#22
@ MBounds The previous owners had already done that a number of years ago. They left the original ground attached to the air cleaner mount, and added another much larger one to the block. There is even a third, small ground leading to the dash area.
@ Amigatec Yep, I've learned much from my short lurking time on these forums. I changed the oil out first thing, Shell Rotella T 15W-40 only. I'm in the Guthrie/Edmond area, just down the road from you. @mikepc Once it fired up, then I really felt like a crook. @Matt G. Check, check and check. You guys are a great source of advice. I've only run it for a minute at a time so far, so I'll get some fuel additive in asap. |
#23
Once I get all the gunk flushed out of the engines I run amsoil in everything
Nick. Cub cadets 100, 125, 86, 108, 109, 128, 129, 129, 149, 149, 169, 1450, 1650 and a handfull of parts tractors. #40 box blade, ih back blade, rear ih rock rake, #2 cart, windbreaker soft cabs, windbreaker hard cab, cozy cab, kwikway loader , wards corn planter, brinly plows, culitvator, rear blade, disc and the usual decks, snowblowers and 2 tillers |
#24
See, why can't I get deals like this?
THEIF!!!!!!!!!!!!!!!! We have a THEIF here!! |
#25
I have in-laws in Norman, I live in Haskell.
Pat Benner Haskell OK Keep the Deck down and the Throttle open!!! |
