I would suggest you resist the temptation for further tinkering as long as it's running well.
I may just do that when my Champions start to go.. They have less then 20 hours on them and still look like new (sharp edges).
I no doubt need to fix that slack in the exhaust valve, but other than that perhaps it will be ok.. |
Better check that slack. I can't remember which engine, but I've seen the stud pull out of the head on the rocker. May have been the Kohler V-twin, but it may have been the Vangaurd... I don't remember.
But I started it up and running fine still! Hope it stays that say! |
If the push rod is popping out of the rocker you have some sort of problem. My guess is you have a valve hanging up. Or you have an over heating condition causing the valve to stick in the open position. I suggest that you find out what is causing the problem before it gets more expensive. Did you check the valve clearances, or did you just pop the push rod back in place?
I set the valve clearance last year.. thinking it was still ok.. The engine has less then 30 hours since I adjusted all the valve clearance.. Maybe I screwed up on that valve and should redo it.. I probably should also double check that the push rod is not bend as well. Some reason I recall an issue with the rockers and push rods on these models.. Another question.. Sorry I have so many! I noticed with the oil fill cap off and engine running.. Lots of air was blowing out! I assume this is probably do to failing head gaskets? I am not too worried.. I don't have a pressure tester anymore.. but I figure it's piston rings or head gasket.. and since the exhaust is not blowing smoke.. I assume the better bet is head gaskets.. My assumptions good on this? The task does not not look too bad.. Should be fun.. When I get some time I'll purchase the new head gaskets.. Thank you all again! |
