i just got a cub 1863 last weekend it has the 54" deck gound leaves with it and rode around yard with it everything worked fine @ 65 degrees tryed starting yesterday @ 34 started fine but when i engaged mower it stalled engine after trying a few times it worked any idea what caused it thanks
did you let it warm up a min or two? they can be a little cranky with a cold engine.
1782, 1862, 1440(sold), 89 1050, 128, 70, some run some don't! 72 scout IH 404 tractor |
My 1864 (same engine) is the same way. It needs about 10 minutes to warm up when it is cold out.
Travis 1993 Cub Cadet 2064 1988 Cub Cadet 2072 1980 IH Cub Cadet 782 w/CH20 1966 IH Cub Cadet 102 w/K301 1961 IH Cub Cadet O 1967 IH Cub Cadet 102 & 122 ![]() ![]() ![]() ![]() JD 2155 w/ 175 loader |
thanks all i was hoping that be the case i will try it
Same here, I always check my oil, start up the machine then let it sit for about 10 minutes or so while I grease the front axle, wheels, deck, etc for the job ahead. By the time I'm ready, it's ready.
-Ryan
