Hot Rod "O"
Ive been hangin on ti this '62 "O" for awhile hoping to find a parts donor but nothing has shown up locally. I bought the tractor as is because I needed the aftermarket engine on another project. I dont want to chop/modify the tractor but I do want to put it to some use....
So last weekend I picked up a 16hp opposed twin Onan I can install using an adapter plate, I can cover the battery and front of the steering tower with a polished aluminum firewall and build a custom 'hot rod' style grill to conceal the fuel tank. Dual stacks, no hood.... and use it just as a wagon hauler at the local annual farm/tractor show.
Lance / Alberta Can IH 127 w/deck, snowblade IH 154 Loboy(x2) w/creeper 3pt and 3160 deck CCC 12.5 w/deck Plus 35 or so non IH tractors |
Oh this will be neat, I'm going to be sure to follow your progress!
-Ryan
That will be a beast! Looking forward to your posts!
Brian April 1979 1200 Quietline 44A deck 1988 1211 customized into a 1288 with a K301AQS 38C deck and a 1864 54” deck . Snow blades 42" and 54" . Brinly disk, brinly plow a cultivator and a $5 brinly yard rake! |
I pulled the O into the shop and set the engine in place so I can get some measurements and see what Im up against. I'll have to design and fab a pulley on the engine but mechanically it looks to be a simple enough transplant. Will even have room to add a front pto later on if needed. Put a couple pieces of abs pipe over the exhaust ports as substitute stacks to get an idea how it will look.... and I think it looks promising. I work in a large custom metal shop so most of the fabrication will be simple to do and cheap, although we cant make a nice aluminum gas tank so I may have to out source for that.
link to the dropbox folder for the Cub Cadet "O" https://www.dropbox.com/sh/v9cjse9qf...9ILOFFrQa?dl=0
Lance
I f all your going to do with it is tow a wagon you can turn the engine around and drive it off the end with the pulleys, you only need the flip the ring gear in the rear.
Looks pretty cool, Lance! I may drag my O out of the barn today and see how my 23 horse diesel looks on it!
Travis 1993 Cub Cadet 2064 1988 Cub Cadet 2072 1980 IH Cub Cadet 782 w/CH20 1966 IH Cub Cadet 102 w/K301 1961 IH Cub Cadet O 1967 IH Cub Cadet 102 & 122 JD 2155 w/ 175 loader |
The crank would look cool hanging down as it stuck out of the grill!! Cranking the machine to start it would even be cooler!! |
I actually wondered if flipping it around might be possible but then the hot air off the engine would be blowing right at my legs so that may be a little uncomfortable. With engine this way all that air will be pushed out the grill and I'll still have the option to put a pto on the front if/when I find a purpose for one... and just for the 'cool' factor... it could still have a hand crank... I hadn't thought about that possibility.
Any ideas are welcome and appreciated
