Old 12-16-2014, 08:35 PM
garnold's Avatar
garnold garnold is offline
Default How to remove front PTO off 73
I've been checking all over for steps on how to do this. Which manual describes the proper way to remove the pto and bearing plz. Thanks :-)
108 upgraded to 12hp
127 with all the trimmings
73 WIP
75 WIP
Blade, blower, decks
Tons of left over parts
Old 12-16-2014, 09:16 PM
garnold's Avatar
Ok, just another one of my rookie calls. I figured out how the set screws come out. And as always, the first 4 come out great then the top one of the last set seems striped 😁 I have it soaking in PB blaster hoping it breaks free. If not that then I'll see if an easy out can fit in there. Any other ideas?
73 WIP
75 WIP
Old 12-16-2014, 09:43 PM
Gene the trick is to go back and forth with the stubborn ones, if you feel them start to tighten up then turn them back in and then turn out a little further. Each time going a little more. The bearing behind it has a locking collar that you have to turn CW to loosen as it is somewhat of an eccentric. Plenty of write ups on here with many tricks, tips, and oops now what's. Good luck and take your time. Breaking a set screw or stripping one adds a lot of time. I use a pitman arm puller to pull off Pto bearing
Old 12-16-2014, 09:46 PM
Originally Posted by garnold View Post
Ok, just another one of my rookie calls. I figured out how the set screws come out. And as always, the first 4 come out great then the top one of the last set seems striped �� I have it soaking in PB blaster hoping it breaks free. If not that then I'll see if an easy out can fit in there. Any other ideas?
Make sure the allen / hex wrench has fresh corners. Grind the end if necessary to get good edges. ( do not get it hot or you will lose the temper )
I find KROIL works better than PB Blaster. A 50/50 mix of acetone and ATF works just as good as KROIL too.
If it is stripped, use a "F" drill ( .257 ) to make a spot on the top set screw. Just go far enough to get full diameter . Change to a 13/64" or 3/16" drill and SLOWLY drill thru the set screws. Use oil take your time. If the drill bit gets dull, resharpen or use a new/fresh on.
Once thru, use the 13/64 " thru the hole and then use a 1/4-20 NC tap to clean the threads. Purchase all new set screws when you reassemble.
I've already had my fun with stripped set screws
Old 12-16-2014, 09:48 PM
I use this
Old 12-16-2014, 09:53 PM
Billy-O's Avatar
Billy-O Billy-O is online now
What does the frozen pizza have to do with the front PTO removal?
Plow blade
#2 Cart
QA36 snowthower
Old 12-16-2014, 09:56 PM
Parts box ( plus a guy has to eat )
Old 12-17-2014, 05:52 PM
That's awesome Jeff. I spoke with Lew the other night about your basket pulley removal tool, did you ever add that one to the parts page? That bearing puller one is great, simple and effective. I just used a big posi lock puller to get a basket pulley off with some heat but it was tricky not to bend it, need to pull it from the middle hub area like yours
Old 12-17-2014, 08:04 PM
sawdustdad's Avatar
garnold,
There are some videos on youtube that show how to remove the PTO.
Old 12-17-2014, 08:27 PM
Yes, the PTO pulley puller is on my parts page.
