Old 03-02-2015, 08:28 PM
Lew, on Cubs site it says the fronts are NLA but the rears are still available. Are they still available at Weingartz for sure?
you should call them to be sure.
Up to 534 and counting...
Old 03-02-2015, 08:33 PM
Originally Posted by Tankman View Post
Thanks again Lew. P/N 734-3009 is listed for 10" wheels (I think ).
I'm looking but wonder, "Why have manufacturerrs done away with the hub caps?"
That part is correct for a 12" cub cadet rim.
these are them on my 107.
Old 03-02-2015, 08:51 PM
Too much chrome, I don't do shinny stuff. Oh Yeah I'm lazy.
Old 03-03-2015, 05:00 AM
Tankman's Avatar
Tankman Tankman is offline
They look great! Knew you would have 'em all shined up too!
As they should!
Tankman
'95 CCC 1641
Eastern PA
USMC
Old 03-03-2015, 07:30 AM
dbuck dbuck is offline
Back in the 60's early 70's, they were plain ones offered by Sears for their GT's. Such as, Suburban 12,14, 16 and etc. I see them popup on E-bay every now and then. I have a set on my 149.
Old 03-03-2015, 10:36 AM
Tankman's Avatar
Originally Posted by DoubleO7 View Post
Thanks 007!
Here's how Mooney responded:
Most likely it’ll have to be screw on type discs, but if it’s on tractor and don’t drive too fast, then Velclo, or double sided tape might be sufficient to keep them in place.
What we need from you is overall diameter measurement on wheel where you want discs to sit in. our regular 12” discs measure 12-3/4”.
If you can let us know that measurement, we can make them up for you even if it’s not 12-3/4” for additional charge.
Thank you!
Tankman
'95 CCC 1641
Eastern PA
USMC
Old 03-03-2015, 10:40 AM
I'm looking but wonder, "Why have manufacturers done away with the hub caps?"
Because they are ugly. Hub caps are for cars, not tractors.
Old 03-03-2015, 11:07 AM
Tankman's Avatar
I guess you're right, work.
Reminds me of 4-wheeling on the desert when I lived in AZ. Knew the chrome polished wheels on 4-wheelers meant, "I look cool but, I don't work!"
Tankman
'95 CCC 1641
Eastern PA
USMC
Old 03-03-2015, 08:14 PM
DoubleO7's Avatar
DoubleO7 DoubleO7 is offline
Adding chrome, fancy paint and other bling to a Cub cadet is no different than doing the same to trucks, semi's, etc. None of it makes them run or work any better but it still gets done.
Those 12-3/4" dia. disc would fit just inside the turn out on a 12" CC rim.
Which hubcap was Mooney's talking about there? the spun aluminum one?
Old 03-03-2015, 08:38 PM
Tankman's Avatar
Yes, with a clear coat.
Tankman
'95 CCC 1641
Eastern PA
USMC
