Kohler Courage 25hp
Over the past several months, I noticed a drop in rpm(s) on my C.Cadet LT1050 garden mower. It's powered by a 25hp V-Twin OHV Kohler Courage engine. To check the rpm range, I purchased & installed a tach/hour meter. At idle it averaged 1920 rpm and at full throttle it hovered at 3240 rpm. When place under full load (pto engaged) it registered 3050 rpm. Can anyone please advice as to the proper idle & max range. Additionally, if the rpm(s) need adjustment, how do I accomplish this as a DIY owner. Hopefully provide "how to" video site/links where I may review the steps on rpm adjusting. Thank you in advance.
Hello.... If yous is in fact the SV730 V-Twin I did find the manual and on page 26 it explains how to adjust RPM. Hope it helps...
http://www.kohlerengines.com/onlinec..._690_01_EN.pdf
2013 Cub Cadet LTX KW 46" Troy-built string trimmer Craftsman 12V Electric Blower |
Thanks you for quick response. Yes it is the SV730 engine. I will review page 26 and save the manual to my computer for future references.
You're welcome! Hope it helps. According to the manual it seems easy enough.... Good luck!
